Author Topic: How do I move my music and movies from my Mac to my MED500X  (Read 5433 times)
Offline gillesjhb
« on: April 16, 2011, 08:26:14 am »
Hi everyone,
I bought a MED500X and would like to transfer all my music and movies from my Mac Pro.
What is the best way to do it?
I was using my Mac Pro as a TV so I have many movies to transfer.
Some are over 7GO in mkv format
All my movies are saved on one hard drive (Mac OS etendu (Journal))
Apparently I am not able to transfer from this hard to MED500X...
Any thoughts ??
Cheers
« Last Edit: April 16, 2011, 09:44:50 am by Maasbommel »
Offline _Technology_
Re: How do I move my music and movies from my Mac to my MED500X
« Reply #1 on: April 17, 2011, 06:30:11 pm »
if you have internal HDD in your MED it is easy as it could be...connect MED with USB with your computer and copy (cut)/paste all files you want on your MED HDD ...and that is it
Never take life seriously. Nobody gets out alive anyway.
Offline swedotech
« Reply #2 on: July 09, 2011, 11:23:00 am »
I have also tried to copy ripped dvds from my MAC i5 to the Md8tor, no luck please any body help !!!!
« Reply #3 on: July 09, 2011, 11:29:31 am »
Read this:
http://www.mede8erforum.com/index.php/topic,4871.0.html
You need to install an NFS driver on your Mac if the mede8er disk is formatted by setup and you connect to your mac by usb cable.
