Author Topic: Ins Replat & CM Skip Problem  (Read 445 times)
a616
« on: January 23, 2012, 07:48:09 am »
Hi Guys,
I need help on something, when I'm watching any video (from an external hard drive plugged into my Mede8er), the video freezes when I press the "Ins Replay" or "CM Skip" buttons. This didn't used to happen before. Any ideas? Thanks!
« Reply #1 on: January 23, 2012, 06:01:36 pm »
Is this on all your movies or only on some?
a616
« Reply #2 on: February 16, 2012, 10:31:55 am »
Sorry, I just saw your post. It doesn't happen with all videos....
« Reply #3 on: February 16, 2012, 07:55:27 pm »
With which one does this happen?
All with the same extension and same video codec?
a616
« Reply #4 on: February 17, 2012, 01:33:23 am »
I'm not familiar with codecs, but extensions are mostly avi.
« Reply #5 on: February 17, 2012, 08:02:24 am »
Try Media Info Analyser.
You can find it here:
http://www.mede8erforum.com/index.php/topic,10.0.html
Use text view when you have opened a media file with it, and compare the files that run and don't run normal with this avi extension. My guess is that you will see that the footprint is simular from those that give this issues.
« Last Edit: February 17, 2012, 10:50:33 am by Maasbommel » Logged
a616
« Reply #6 on: February 17, 2012, 10:44:02 am »
Will do, thanks!
