Author Topic: Y2M Update V1BETA8 -- 2 October 2011  (Read 7003 times)
Administr8or
« on: October 03, 2011, 08:18:09 am »
New Y2M V1.0.8
32bit
http://www.mede8er.org/beta/Firmware_Final/Y2M_BETA8_yamj-2.5-SNAPSHOT-r2665_32BIT_2Oct2011.zip
64bit
http://www.mede8er.org/beta/Firmware_Final/Y2M_BETA8_yamj-2.5-SNAPSHOT-r2665_64BIT_2Oct2011.zip
Pls delete your old YAMJ/Y2M installation and use the complete pack in the above links.
Changelog
* Fixed compatibility problem with latest YAMJ builds.
* Many YAMJ fixes in version r2666 visit YAMJ website for details http://mediaplayersite.com/YAMJ_Latest
Online Multi-Language User Guide  http://www.mede8er.com/mede8er_y2m_user_guide.html
We suggest you change the variable 'max_plot_length' to 400 to stop the images being cut off at the bottom of the image.
If the above does not help then open the default skin's folder in YAMJ and you will find a file skins-options.xsl. Look for the parameter plotlength. It is normally 850 and you can change it to 840.
« Last Edit: November 20, 2011, 07:57:10 pm by Mede8er1 » Logged
