Author Topic: no subtitles on streamed movies  (Read 848 times)
Gildo
« on: March 30, 2011, 08:33:48 pm »
hi , i have a 400X and everything is working fine except when i stream a movie from my pc to the mediaplayer it doesn't show the subtitles.
if i do the same movie via usb stick the subtitles did work.  & the srt file is in the same map and has the same name as the .avi file.
how can i get this to worK?
thanks
« Reply #1 on: March 30, 2011, 08:52:12 pm »
How do you stream?
With Upnp? That will not work with external subtitle files, only with embedded.
And that is for all devices that use the Upnp protocol is my experience..... It comes with the protocol.
If you want to stream movies and use external subtitles, use NFS or normal filesharing to stream (samba - windows filesharing).
Gildo
« Reply #2 on: March 30, 2011, 09:11:04 pm »
what is samba - windows filesharing?
and NFS?
thanks for the help
« Reply #3 on: March 30, 2011, 09:27:28 pm »
I suggest start reading my mede8er beginners guide, see my footer for the link or look in the tips section.
See the FAQ section.
Tips section can be found here;
http://www.mede8erforum.com/index.php/board,45.0.html
For the basics on windows filesharing (called samba under linux) and NFS suggest also to try google.
Gildo
« Reply #4 on: March 30, 2011, 10:05:29 pm »
i think i use windows fileshare. is it with that workgroup and stuff?
also, i have problems playing streamed mp3 files. they won't play. via usb they play.
« Reply #5 on: March 30, 2011, 10:13:22 pm »
Yes, if you goto the Network menu in media library and you goto Workgroup or by the Shortcut entry, then you are streaming with filesharing.
Regarding subtile .srt files, be sure that you use the same exact letters, it is case sensitive.
Then you should be able to toggle to the sub title using the subtitle button on your remote and then pressing up/down button to select the subtitle.
What network connection do you use?
Wifi or lan cable connection?
« Reply #6 on: March 30, 2011, 10:26:18 pm »
Also be carefull if your windows is set to hide known file extensions.....
If you name for e.g. movie.srt be carefull its not movie.srt.srt
