Pages: 1 ... 3 4 [5] 6 7   Go Down
Author Topic: Can't access to mede8er after firmware upgrade 4.0.4  (Read 9173 times)
« Reply #60 on: March 11, 2011, 09:59:15 pm »
I had the same problems after upgrading to 4,04.
I never changed any settings in my PC, used auto-ip on my med.
After resetting my router and reinstalling 4,04 iīm abled to connect to the med.
So my problems are solved
cheerz
Ruud
Can you confirm if you have a Router DNS Proxy or not?
bergh361
« Reply #61 on: March 11, 2011, 10:05:12 pm »
I have No router DNS proxy
cheerz
Ruud
« Reply #62 on: March 12, 2011, 01:03:58 pm »
So your sequences was:-
Install 4.0.4 - Nas dosn't work
reset router (med still using 4.0.4)
Re-install 4.0.4 - Nas works.
Getting 4.0.4 to work is diffcult if we can't be sure the code is running as it should due to  a poor install. We could just tell everyone to  install again but I'm not sure how well that would go down. How many times could we expect users to do that before looking at the problem itself?
bergh361
« Reply #63 on: March 12, 2011, 01:26:27 pm »
Thatīs exactly the sequences i followed
myki
« Reply #64 on: March 12, 2011, 02:23:16 pm »
Thanks!
I lost my NAS feature when I upgraded to 4.04. I re-flashed v4.04 firmware (without reseting router), and it now works perfectly.
myki
« Reply #65 on: March 12, 2011, 03:50:12 pm »
Thanks!
myki
It would be interested to know what upgrade method you used the first time.
Did you use the upgrade option from Mede8er setup or did you use the Firmware Recovery method as mentioned in the release notes of the firmware?
myki
« Reply #66 on: March 12, 2011, 04:10:53 pm »
I used the procedure in the release notes in both instances. The only difference between the 1st and 2nd is the flash drive I used which should be insignificant.
« Reply #67 on: March 12, 2011, 04:22:20 pm »
You might have had a corrupted format on your flash disk that caused a corrupted install.
« Reply #68 on: March 12, 2011, 06:03:51 pm »
It's a shame there is no way of performing a CRC check on a download, and do a byte by byte verify on an install.
« Reply #69 on: March 12, 2011, 06:10:15 pm »
As far as I know winrar will do a CRC check when you unpack.
trust
« Reply #70 on: March 12, 2011, 06:24:58 pm »
Thanks!
myki
I had exactly the same issue here.
I did an upgrade from 4 final to 4.04 and NAS function was gone.
After re-installing 4.04 it just works again!
I used the same unpacked image file on the same usb-stick with the same procedure and I didn't reset the router.
« Reply #71 on: March 12, 2011, 07:13:23 pm »
I get the impression this issue isn't even about a bad firmware upgrade. Something happens to how the network percieves the Med on the first install and it's presence on the network is only complete after the second.
RSWoning
« Reply #72 on: March 13, 2011, 01:57:48 pm »
Same here.
Didn't reset anything. Re-installed with the same image on the same USB device. Switched on NAS, and it works!
One strange thing: After the 1st install, I changed the Hostname of the Mede8er since Windows 7 also suggested a problem with the hostname. That didn't fix it. After re-install of 4.0.4 the name change was gone and the original name I gave it before the upgrade was in the config.
« Last Edit: March 13, 2011, 02:58:50 pm by RSWoning » Logged
zaprudanec
M8 pocetnik - svaka pomoc i savjet dobro dosli :-)
« Reply #73 on: March 13, 2011, 02:00:24 pm »
Thanks!
myki
me too
Mede8er model: MED500X
Board: 1073DD C+
Bootloader: 0000.0202.1026
Firmware: V4 Jan 25 2011
Internal HDD: WD20EADS 3.5" Caviar Green 2TB SATAII 64MB
Linksys wireless router with Ethernet Switch
Display: HDMI to Philips 42PF9631D/10
Audio-Video connection: HDMI to Pioneer
Pioneer VSX-2016AV-S
BlizzRD
« Reply #74 on: March 13, 2011, 07:44:09 pm »
Weird. But just re-installing works for me too.
Pages: 1 ... 3 4 [5] 6 7   Go Up
