Pages: 1 ... 3 4 [5] 6 7 ... 20   Go Down
Author Topic: feedback on v4.0.4 final release  (Read 40245 times)
BoTiA
« Reply #60 on: March 05, 2011, 01:18:22 am »
after upgrade from 3.04 to new 4.04 I notice that audio is little bit quiet. I tried to change night mode settings, but only difference is when I put it on Comfort.
when it is on "night" or "none" it is still  little bit quiet for me ...
anyhow .. video wall is good to see, but I am not impressed too much...
nukie
« Reply #61 on: March 05, 2011, 08:21:10 am »
@Maasbommel
-Bootloader: pached 17 (have 26, I could not have firmware 4.0 without it)
-Not using an usb 2.0 compliant usb stick: USB is the same used for all previous updates (I use the HP tool to formated it 2x)
-Having a hanging hdmi port that stops the update: I have not tried it, I'll tell if passes.
- Having downloaded a corrupted firmware or corrupt the fw while unpacking: I downloaded two times? Unpacking withouth probs.
Thank you for your prompt reply.
What program did you use for unpacking?
Mede8er V4.0.4 working great
WD10EADS 1TB wired LAN
HDMI via Onkyo TX-SR606 7.1 to SONY KDL40D3500/LG32LC51/Samsung 32
Qnap TS-239 pro (NFS) 3.4.0 Build0212
Netgear WNDR3500L TomatoUSBmod, D-link DGS-1008D
the-osiris
B8a Tester - 1000X3D
« Reply #62 on: March 05, 2011, 09:14:38 am »
i always get error  that the firmware is not right for my model , but  i have tried  both  for MED500X  and same error
"Mede8er firmware will not work on this hardware"
Check again, you might accidentally download firmware for MED400X.
@Maasbommel
Use Composite to TV while upgrading firmware.
You can check downloaded firmware using HashCalc, and here's the MD5 hash for both version :
MD5 5906562b82d22e9c4abc56f3ab66a261  INC_HD_Audio
MD5 a65920bebaaa63085d34c151f1ba634e  NO_HD_Audio
Night mode is simply "normalizing" sound input, so there's no shocking sound while watching movies. It will increase low volume sound, and cut high volume sound, but it depend on the source.
There's still has Media Library if you don't want to use Videowall   Wink
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
« Reply #63 on: March 05, 2011, 09:48:42 am »
Are you using an amp for audio? be sure your audio setting is on max +31 on your mede8er.
sergeich27
« Reply #64 on: March 05, 2011, 09:53:31 am »
Older DD hardware cannot switch MED500x off with front on/off button - fixed
Not working front on/off button  Sad
FLAC files not playing on .cue files Sad Only APE files playing.
« Reply #65 on: March 05, 2011, 09:54:25 am »
What was the player doing when you pressed on/off on the front?
Does it work when you are in the home screen?
sergeich27
« Reply #66 on: March 05, 2011, 09:58:57 am »
Is not switched off from any place. Standby mode working. But full power of with long press button not working Sad
mobetterblues
« Reply #67 on: March 05, 2011, 11:39:11 am »
Tried that twice, but the issue remains.
The strange effect of the logo moving around the screen and painting the screen black as it goes is weird.
I set the screen saver to 'on' at five minutes this at least stopped the problem of having to exit all the way out to the top level.
So at least the screen saver stops
So no more help then?Huh
Also the subtitle issue on video_ts files remains.
When will this be fixed, it's starting to become a major annoyance?
I've even started looking at other media players because of this.
« Reply #68 on: March 05, 2011, 11:48:42 am »
I am not able to reproduce this with the screensaver.
Have not seen more people yet with same, only one and that was caused by using config restore.
Reloading firmware solved it.
What do you mean with video_ts issue and subtitles?
Can you give some more detailed info on this? What do you see exactly and is it on all?
« Last Edit: March 05, 2011, 12:03:55 pm by Maasbommel » Logged
bocombo
« Reply #69 on: March 05, 2011, 01:30:06 pm »
What is the version of your bootloader?
And please read this:
http://www.mede8erforum.com/index.php/topic,4798.msg32540.html#msg32540
My problem is solved. I had a hanging hdmi port that stops the update.
I Use Composite to TV while upgrading firmware. All is OK.
A big thank you Maasbommel and the-osiris.
tonio
« Reply #70 on: March 05, 2011, 02:56:44 pm »
can i directly upgrade from v2.0 to v4.0? Thanks.
dizzy0709
« Reply #71 on: March 05, 2011, 04:41:01 pm »
NAS mapping not working after 4.0.4 upgrade, previously working on v4.0. Running Windows 7. I am able to map from Mede8er to pc without any problems.
mobetterblues
« Reply #72 on: March 05, 2011, 04:41:46 pm »
Ok, well I've never used the config restore and the problem remains.
As stated I have now set the screen saver to 5 mins which although not what I want ti does cure the problem of having to exit all the way to the top level.
The subtitle issue is on all my video-ts folders, regardless of what software I used to rip them, the subtitles always appear until the subtitle's are turned off when playing.
The subtitles are set to off in the settings but it makes no difference.
This has been noted in several posts for previous firmware, so why do you ask 'what issue'?
« Reply #73 on: March 05, 2011, 04:52:40 pm »
Your one of the unlucky users for which the new SDK has created DNS/WINS problems. You csn turn the NAS on can't you? We do have one users who can't turn it on at all.
dizzy0709
« Reply #74 on: March 05, 2011, 05:01:35 pm »
Yes - NAS can be turned on and is enabled. Is there workaround for the DNS/WINS problems ?
Pages: 1 ... 3 4 [5] 6 7 ... 20   Go Up
