sirhenry
Offline
« Reply #195 on: April 24, 2011, 02:51:31 pm » |
I think this new firmware [CENSORED]; I can't get the screensaver off, it goes out on after 60 sec or so even if i put it off in the menu. Often i got some blurr (blocks) during watching an MKV video. The menu works like on thick oil...much slower then teh previos version. I'm very dissappointed.
« Reply #196 on: April 24, 2011, 07:22:14 pm » |
I suggest you reinstall again. This behaviour is not normal and might be caused by some corrupted fw install. Check first if you have bootloader version 26. Suggest to first install V4beta5 to reinstall the bootloader. After that install 4.0.4 again. Be sure to use a full formatted usb stick, you might consider to use the HP format tool as mentioned in the firmware release notes. You can find the mentioned firmware with release notes here: http://www.mede8erforum.com/index.php/board,46.0.html
3kb6vs9b1
Offline
media eater
« Reply #197 on: April 27, 2011, 08:56:34 am » |
Maasbommel, if the USB formatting is so crutial then why don't you create application that makes all in one: formats the USB and copies the FW onto it. Maybe also add bootloader "thing". Isn't it frustrating that there it almost nothing else to read in forum lately than users might have corrupted FW.
« Reply #198 on: April 27, 2011, 06:55:24 pm » |
Take in mind that there are thousands of mede8er users that have done the update without any problems. The few you see here are the exceptions, no matter what update procedure or tool is supplied: you will always see that kind of patterns in an update/change process.
3kb6vs9b1
Offline
media eater
« Reply #199 on: April 27, 2011, 08:10:05 pm » |
But you do not see thousands of thank-yous. New and prospective users come here and see this. It could have impact on your product image.
caka
« Reply #200 on: April 27, 2011, 09:12:54 pm » |
I have install last fw without any problems! Thanke You!
Thxsen
Offline
« Reply #201 on: April 28, 2011, 02:44:41 am » |
I own 2 mede8er400x players. After i installed the 4.0.4 firmware i have problems with the watched indicator that dont work on all files as it did previously. So no eye icon during series.. And yes, the function is on in misc.
norzain
Offline
« Reply #202 on: April 28, 2011, 02:46:39 am » |
Thanke You!
Me too..  And now I am using FW 4.0.4 Mod by Bro Shizzl, it's more fun!
Kokkeman
Offline
« Reply #203 on: April 28, 2011, 05:20:20 pm » |
I have followed the update description and updated the med500x from 3.04 to 4.0.4 without any problems. Tip though, it could be that you dont see the progress bar if connected via hdmi so during update i had connected the med via composite cable.
New GUI and Video Wall looks great.
The only minor in my opinion is that: a- you can't place a movie under more than 1 genre. b- if you have a 3 level deep (movie collection\genre\movie1) that you can't browse/see all your movies on the wall, you have to browse per Genre and then see the movies in that Genre. A Total view on the Wall would be nice to have.
Thanks en Regards,
MED500XDD+ 2TB [FW V4.0.4]
tachita_
« Reply #204 on: April 28, 2011, 06:11:48 pm » |
@ Kokkeman try to think at moviewall more like a shortcut... a graphical shortcut
Monde
Offline
« Reply #205 on: May 02, 2011, 11:32:45 am » |
Loving the new release. Thanks.
The only issue I have is that I cannot get the Watched indicator to work. I have turned it on and off. The movies I watched under the old version show up with the eyes but the new ones do not. Any ideas?
saskir
« Reply #206 on: May 03, 2011, 05:38:12 pm » |
Somewhere there is a thread concerning this (on this forum). I would look there. I think it had something to do with a gap which was needed between the partitions.
Monde
Offline
« Reply #207 on: May 10, 2011, 12:58:47 pm » |
I searched and just found where they said turn it on manually....which I did. I am not a very good troll sorry
linuxdancer
Offline
« Reply #208 on: May 14, 2011, 03:55:49 pm » |
This is a forum where the firmware is discussed. It is just human nature to discuss the issues or problems you are having. Ever watch the News, you never hear much about the good stuff going on though there is a ton of it. I used to have a Patriot Box Office where in general the support [CENSORED]. Feel lucky here, where you have a developer who really cares about putting out a quality unit and software. My 2 cents anyway.
the-osiris
« Reply #209 on: May 14, 2011, 04:17:55 pm » |
Some users just visiting this forum when they've got problem, and forgot to give feedback if they've already solved the problem. Yes, it's just natural ..
