Pages: 1 [2] 3 4 ... 20   Go Down
Author Topic: feedback on v4.0.4 final release  (Read 41338 times)
« Reply #15 on: March 03, 2011, 11:15:43 pm »
Yes, I set NAS on. I didn't have this problem with the 3.0.5. By old version everything worked ok, except audio output disturbed me (I would like to have simultaneous on HDMI and SPDIF, like is now in 4.0.4).
Have you tried to connect with the shortcut method?
And what kind of setup do you use on your shared PC folders?
An account with loginname and password or just using Guest account?
« Reply #16 on: March 03, 2011, 11:20:00 pm »
All those who havn't already upgraded will have to check the Change Log for what's been changed, and what is still outstanding. No one should just assume all problems have been eliminated becuase a new version is available.
zaimben13
i love mede8er ! big up for south africa!
« Reply #17 on: March 03, 2011, 11:21:23 pm »
Thank you Zaimben !
Sorry for the confusion.
I believed there were 2 partitions on the HDD, 1 with the OS + 1 with my data.
What about the HDD File System ?
I'm on 3.0.4. Should I have to format my drive and change file system ?
I see a lot of messages talking about the "new file system" on v4 instead of v3.
Am I tired or should I do the upgrade now, without any trouble ?
(I dont have any backup of my HDD, don't want to loose all my movies...).
Thank you !
if you formated your internal hdd with the med.....there shoul be no problem, why changing the file system, dont create difficulty where it shoul not exist .....just upgrade you med and unleashed the power of the beast man!!!
TO ALL THE SANJI TEAM!!!!!!!
 Smiley Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Angry Grin Grin Grin Grin Grin Grin Grin Grin Grin Wink Wink Wink Wink Wink Wink Wink Wink Smiley Smiley Smiley Smiley Smiley Smiley Smiley Smiley Smiley DAAAAAAMMMMMNNNN MY INTERNAL HDD IS NOW FULLY RECOGNISED BY THE MED WITH THIS NEW FIRMWARE!!!!!!!!!!!!!!!
SO FOR THAT  I WANT TO THX ALL OF YOU GUYS!!!!!!!!!!!!!!!!!! i will not have to by 2 new 2 to hdd......save my money and can now enjoy my med with the gui of v4 just GREAT WORKS GUYS!!!!! Wink Wink Wink Wink Wink
im so HAAAAAAAAAAAPY
thxxxxx!
zaimben!!!!
med500x firmware 4.0.4 2to hdd inside +2to external hdd
ps3 slim 250go
xbox 360 elite SLIM  250go
 lcd  LG 27 inch full hd
waiting for  MED1000X3D  release in Europe
gabtom
« Reply #18 on: March 03, 2011, 11:46:43 pm »
Hello.
I have some troubles playing movies with dolby TrueHD audio (m2ts, mkv, ts). My unit plays them without sound ("unknown audio format" information appears). I've got older hardware (DD), so I'm fully aware I can't get full dts hdma or dolby truehd, but from what I understand firmware V.4 should be able to play core sound from these formats? I've installed "No_HD" firmware version, as suggested for SPDIF users. There is no problem when playing dts HDMA, only dolby TrueHD.
Sorry for my english, it's not my native language. Best regards.
leuk_he
« Reply #19 on: March 04, 2011, 12:35:56 am »
I'm afraid to this update.
I have MED500X Release 3.0.4.
Will I loose all my films and media on my HDD when I'll do the upgrade ?
I don't see any of this information in the release notes : http://www.mede8erforum.com/index.php?topic=4793.0
The hdd is not automatically formatted after a firmware upgrade.  The only way to format the hdd in the unit is by choosing the menu item "format HDD"
Note that the mede8ter works best if the HDD was once formatted in the mede8ter.   If not formatted in mede8ter you risk some bugs (e.g. read-only when accessing via network)
of course you do loose the settings (screensize/networksettings/pincode), but it not a lot of work to add them again.
Please fix the Ntfs driver bug, or make ext3 formatting available from gui.
mobetterblues
« Reply #20 on: March 04, 2011, 01:18:01 am »
Update again using recovery mode and don't use config restore, but set all by manually again.
I expect some config restore issue or some corrupt FW install.
Tried that twice, but the issue remains.
The strange effect of the logo moving around the screen and painting the screen black as it goes is weird.
I set the screen saver to 'on' at five minutes this at least stopped the problem of having to exit all the way out to the top level.
So at least the screen saver stops
Harry_993
« Reply #21 on: March 04, 2011, 06:04:04 am »
yep same here, after installing 4.0.4 no access anymore from PC to MED.
Network settings ok, NAS on
even after cold restart (MED + Router) it doesnt work anymore. Ping works fine though, no firewall active.
With previous FW 3.0.5 everything was fine.....
any ideas?
Mede8er  MED500X 1073DD
Firmware: V3.0.5
Bootloader: 0000 0202 0016
Administr8or
Online Online
« Reply #22 on: March 04, 2011, 06:16:34 am »
Hello Harry_993
Did you try putting the host name into the explorer bar eg "\\MEDE8ER"  or IP  "\\XXX.XXX.XX.XX"
Harry_993
« Reply #23 on: March 04, 2011, 06:26:13 am »
yes tried that as well, but still wont work.
Now i just reinstalled 3.0.5 to check again and everything works fine again,
so i guess  we have a small LAN bug comin with the 4.0.4
but no prob, i will stick with the 3.0.5 which works fine for me Smiley
Firmware: V3.0.5
Pungi
« Reply #24 on: March 04, 2011, 08:19:00 am »
Hello, I have access to from Mede8er to PC. I see files in my shared folders and I can use them. So, it works from this side. The problem is, that I see Mede8ers icon in My Computer, but is doesn't response (computer shows an error). It seems, I am not the only one, Harry_993 has the same issue. I hope, it will be fixed soon, because I realy waited on this change in audio output mode.
Regards.
BeenThere
B8a Tester - X2
« Reply #25 on: March 04, 2011, 08:39:01 am »
I'm not sure if this is a 4.0.4 problem, but I am unable to delete a specific directory (and the files within). Let me break it down...
There is a directory in the root of my hdd that I want to delete. It has two sub directories with one file in the last sub directory. That file is a .mkv file. For some obscure reason, the .mkv file somehow inherited the extension of .mkv.t - which I cannot change remotely from my Windows laptop (I get a message saying I need User\Root permission). I also cannot unset the "watched" indicator on the mede8er. When, on the mede8er,  I try to delete the sub directory with the file in, the mede8er hangs. Because it's a .t file, I cannot see the file in that directory, which is correct. From my laptop, I can delete the file, but when I go back into the directory, the file is back.
Please help...
Update: I turned off the Watched Indicator under Setup. The watched icon is gone on the mede8er, but I still cannot delete the file from my laptop. Keeps re-appearing as a .mkv.t
« Last Edit: March 04, 2011, 08:53:28 am by BeenThere » Logged
Model: MED500X2
Internal HDD: WD WD10EARS-00Y5B1 1TB 3.5" SATA
Network: Wireless
TV: 32" Samsung LA32B530P7RXXA
Audio: Optical to NAD T751 AV receiver
« Reply #26 on: March 04, 2011, 09:19:00 am »
Please help...
I expect you have some filesystem inconsistency problem. Connect your mede8er to your PC and run chkdsk from a dosbox.
« Reply #27 on: March 04, 2011, 09:26:46 am »
Regards.
I suggest you start reading/trying this:
« Reply #28 on: March 04, 2011, 09:28:12 am »
any ideas?
BeenThere
B8a Tester - X2
« Reply #29 on: March 04, 2011, 09:42:57 am »
You "expected" correctly. Chkdsk found some errors, which were fixed. Was able to delete the directory after that. Thanks Maasbommel - you the man!
Model: MED500X2
Network: Wireless
Pages: 1 [2] 3 4 ... 20   Go Up
