Pages: 1 2 3 [4]   Go Down
Author Topic: Error on "Run YAMJ" action  (Read 5452 times)
« Reply #45 on: June 29, 2012, 04:55:07 pm »
Maybe the fastest way forward is to do a reinstall of your windows....
Or try Thumbgen in stead, maybe you have more luck with that.
the-osiris
B8a Tester - 1000X3D
« Reply #46 on: June 29, 2012, 05:02:54 pm »
use this tool to complete uninstalling java
http://sourceforge.net/projects/javara/
then reinstall java jre from http://java.com/en/download/index.jsp
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
reevesy
« Reply #47 on: June 29, 2012, 05:14:07 pm »
obviously not keen to do that.....why the same problems on 2 different pcs?
thanks
« Reply #48 on: June 29, 2012, 05:15:34 pm »
I really don't know, but it seems you are one of just a few having this issues, question is only: what is the root cause of this issues...
« Reply #49 on: June 29, 2012, 05:17:15 pm »
I saw you had simular kind of issues more then a year ago:
http://www.mede8erforum.com/index.php/topic,4737.msg32126.html#msg32126
How did you solve those then?
reevesy
« Reply #50 on: June 29, 2012, 05:46:15 pm »
by taking into where it i was working at the time and handed it over to a girl who had just done a java course!
i know she made path changes but cant remmber what she did
used the java removal tool and re-installed it all again...but running the javatester brought up the fault again....i then turned off my zone alarm firewall and it finally showed java to be up and running ?
......zone alarm is set up to allow java so i dont know?
reevesy
« Reply #51 on: June 29, 2012, 06:02:54 pm »
well......
kept zone alarm turned off and ran yamj again..........IT WORKED!!! Shocked Shocked
not sure what was done other than reinstalling java for the umpteen time on top of the other jamj changes suggested??
zonealarm is configured for java and the yamj items showing up in its 'program control' and always worked with this firewall before??
is there anything else i have to check in zonealarm does anyone know?
thanks again
reevesy
« Reply #52 on: July 03, 2012, 04:52:29 pm »
anyone know what the problem is with zone alarm?
the-osiris
« Reply #53 on: July 03, 2012, 05:38:17 pm »
I think you should tell zone alarm (and all firewall) to let Y2M/YAMJ/Java to connect to public net.
As you can see from error logs, that somehow, there's some connection problem during connecting to imdb and tmdb while using Y2M (caused by ZoneAlarm).
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
reevesy
« Reply #54 on: July 05, 2012, 03:07:26 pm »
yep...as mentioned i've already done that
thanks
« Reply #55 on: July 05, 2012, 10:55:13 pm »
I suggest to remove Zonealarm and reboot. After that install again. It should do a rescan for applications.
Sent from my mobile with Tapatalk
poelie
« Reply #56 on: August 11, 2012, 11:41:25 am »
I had the same problem. Error getting url ...
This worked for me...
- Uninstall all versions of Java (java 7, java 6, java fx)
- reboot pc
- install java version 6 update 33
And now everything works just fine again.
hope this helps
MED500X V4 Beta5 with Samsung HD103SI 1TB
TV: LG Plasma 42PG60
AV Receiver: Marantz NR1501 (Canton Speakers)
Remote: Harmony One
Pages: 1 2 3 [4]   Go Up
