Pages: 1 2 [3] 4   Go Down
Author Topic: Error on "Run YAMJ" action  (Read 5384 times)
the-osiris
B8a Tester - 1000X3D
« Reply #30 on: June 27, 2012, 03:58:06 pm »
hi reevesy,
Those files (moviejukebox.log and moviejukebox.ERROR.log) are stored inside YAMJ folder.
Look at mine in the attachment.
From there, we wish to see the main problem. if still has api problem, YAMJ needs an update to newer release.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
reevesy
« Reply #31 on: June 27, 2012, 05:46:24 pm »
well got the latest release...feb 2012
 Huh
reevesy
« Reply #32 on: June 27, 2012, 06:14:06 pm »
found the error log
[14:23:03 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M/skin-user.properties', not found.
[14:23:03 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M\overlay.properties', not found.
[14:23:25 - main    ] WARN  com.moviejukebox.scanner.artwork.FanartScanner  - FanartScanner: Failed to initialise TheMovieDB API. Fanart will not be downloaded.
[14:23:48 - Thread-2] WARN  com.moviejukebox.plugin.poster.MovieDbPosterPlugin  - MovieDbPosterPlugin: Failed to initialise TheMovieDB API.
reevesy
« Reply #33 on: June 28, 2012, 12:44:33 pm »
spent days on this now..... Angry
the-osiris
« Reply #34 on: June 28, 2012, 02:13:53 pm »
hi reevesy,
I have final solution for you, it might not easy but I will explain step by step for you  Smiley
Actually, it's updating your YAMJ to latest build (not Y2M, YAMJ only)
1). Download latest YAMJ build (v2.7 r3142) http://mediaplayersite.com/sites/default/files/YAMJ/yamj-2.7-SNAPSHOT-r3142-bin.zip
2). Extract it anywhere (eg. C:\YAMJ_2.7)
3). Copy 3 folder from previous YAMJ/Y2M (Mediainfo/Skins/Y2M) to this new YAMJ build folder (overwrite it).
4). Delete Y2M registry, then restart your Y2M from this new build (eg.C:\YAMJ_2.7\Y2M)
5). Set new setting, then try to Run YAMJ.
if same problem persist with previous YAMJ build, I have no more solution .. but it worth to try.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
reevesy
« Reply #35 on: June 28, 2012, 06:44:39 pm »
thanks will try that
reevesy
« Reply #36 on: June 29, 2012, 11:38:54 am »
jesus christ!....to coin a phrase!
when i click on the delete registry after typing yes in the dos window i get an error flash up...too quick to say what it is
....EDIT....at least fixed this
...opening the yam build zip by 'extracting here' with win rar does'nt put it in a folder but scatters different folders...4 or 5 i think
....is this right or do i have to creat a folder to put the zip file in.....then extract here??
....far as i've got so far
thanks
« Last Edit: June 29, 2012, 01:24:27 pm by reevesy » Logged
reevesy
« Reply #37 on: June 29, 2012, 12:17:05 pm »
right  Huh Sad
....now trying to 'move and replace the   3 folders you mention from the original yamj to the 'new build' one....i've moved the media info folder...and the skins folder......but the last one you mentioned Y2M....ie you posted (mediainfo/skins/Y2M)....cant find or see a Y2M folder in the original yamj feb 2012 download extracted zip to move across to the 'new build folder???
 Huh
reevesy
« Reply #38 on: June 29, 2012, 12:24:03 pm »
well after all that so far.....moving the 2 out of 3 folders as i could'nt find the third one mentioned
...still did'nt work...it ran but this error log
[11:21:05 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M/skin-user.properties', not found.
[11:21:05 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M\overlay.properties', not found.
[11:21:29 - Thread-1] WARN  com.moviejukebox.plugin.poster.MovieDbPosterPlugin  - MovieDbPosterPlugin: Failed to initialise TheMovieDB API.
[11:21:50 - Thread-1] ERROR com.moviejukebox.tools.WebBrowser  - WebBrowser: Error getting URL http://www.imdb.com/find?q=Ronin+%281998%29;s=tt;site=aka, Connection timed out: connect
[11:22:11 - Thread-1] ERROR com.moviejukebox.tools.WebBrowser  - WebBrowser: Error getting URL http://www.google.com/search?q=Ronin+%281998%29+site%3Awww.imdb.com&meta=, Connection timed out: connect
[11:22:11 - Thread-1] WARN  com.moviejukebox.plugin.DatabasePluginController  - Video 'Ronin.(1998)' was not able to be scanned using the current plugins
[11:22:13 - Thread-5] WARN  com.moviejukebox.MovieJukebox  - Error reading the poster file: C:\YAMJ\Jukebox\Ronin.(1998).jpg
[11:22:13 - Thread-5] ERROR com.moviejukebox.MovieJukebox  - Failed creating poster for Ronin
[11:22:13 - Thread-5] ERROR com.moviejukebox.MovieJukebox  - java.io.FileNotFoundException: C:\YAMJY2M latest build\temp\Jukebox\Ronin.(1998).jpg (The system cannot find the file specified)
   at java.io.FileInputStream.open(Native Method)
   at java.io.FileInputStream.<init>(Unknown Source)
   at com.moviejukebox.tools.FileTools.createFileInputStream(FileTools.java:424)
   at com.moviejukebox.tools.GraphicTools.loadJPEGImage(GraphicTools.java:93)
   at com.moviejukebox.MovieJukebox.createPoster(MovieJukebox.java:2299)
   at com.moviejukebox.MovieJukebox$7.call(MovieJukebox.java:1448)
   at com.moviejukebox.MovieJukebox$7.call(MovieJukebox.java:1438)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
   at com.moviejukebox.tools.ThreadExecutor$ScheduledThread.run(ThreadExecutor.java:95)
the-osiris
« Reply #39 on: June 29, 2012, 01:38:48 pm »
Y2M folder is the folder contain Y2M main program (YAMJ_To_Mede8er_2.0.0.exe).
did you delete Y2M registry before starting a new build?
from error logs, I can see there's something wrong with java (API) and internet connection, did you have an NFO file in movie folder (contain imdb site id) ?
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
reevesy
« Reply #40 on: June 29, 2012, 03:12:27 pm »
yep did delete registry...after finally getting it to work.....was typing yes and was getting a flash of an error....tried typing Yes...with a capital Y and it seem to work
befor i go further...i've noticed my moviejukebox.sh is'nt called 'sh'...its just called MovieJukebox (says its an sh file under 'type)....and the moviejukebox.bat is just called moviejukebox (again says it's a batch file under type)
i downloaded and reinstalled yamj from various places loads of times now and it's always the same
...tried using 'TOMY' as well but that said that no sh file was detected and no batfile was detected etc
have just done a totally uninstalled delete re start yet again and going to try yet again
...must admit i'm getting close to giving up on it
...tried my other 64bit laptop as i remembered i had yamj on there to......currently got the dreaded java problem on there as well  Angry
reevesy
« Reply #41 on: June 29, 2012, 03:18:23 pm »
right now from a complete install of the latest YAMJ and not changing anything as previously discussed i've now got a  'could not create java virtual machine' error....nothing mentioned about object heap?
java path 'QTJAVA' is there and correct
before anything else...is this now fixable from here?
thanks
reevesy
« Reply #42 on: June 29, 2012, 03:33:53 pm »
hi reevesy,
well bit the bullet  and did this.....got the java problem...then went back into the moviejuke files in the 'newly built yamj' and redited the figures to 512 as recommended
...re ran again....got the same fault as before with no movie art
this error log
[14:23:51 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M/skin-user.properties', not found.
[14:23:52 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M\overlay.properties', not found.
[14:24:14 - main    ] WARN  com.moviejukebox.scanner.artwork.FanartScanner  - FanartScanner: Failed to initialise TheMovieDB API. Fanart will not be downloaded.
[14:24:38 - Thread-2] WARN  com.moviejukebox.plugin.poster.MovieDbPosterPlugin  - MovieDbPosterPlugin: Failed to initialise TheMovieDB API.
[14:24:59 - Thread-2] ERROR com.moviejukebox.tools.WebBrowser  - WebBrowser: Error getting URL http://www.imdb.com/find?q=The+Usual+Suspects+%281995%29;s=tt;site=aka
[14:25:20 - Thread-2] ERROR com.moviejukebox.tools.WebBrowser  - WebBrowser: Error getting URL http://www.google.com/search?q=The+Usual+Suspects+%281995%29+site%3Awww.imdb.com&meta=
[14:25:20 - Thread-2] WARN  com.moviejukebox.plugin.DatabasePluginController  - Video 'The.Usual.Suspects.(1995)' was not able to be scanned using the current plugins
[14:25:21 - Thread-6] WARN  com.moviejukebox.MovieJukebox  - Error reading the poster file: C:\YAMJ\Jukebox\The.Usual.Suspects.(1995).jpg
[14:25:21 - Thread-6] ERROR com.moviejukebox.MovieJukebox  - Failed creating poster for The Usual Suspects
[14:25:21 - Thread-6] ERROR com.moviejukebox.MovieJukebox  - java.io.FileNotFoundException: C:\YAMJ_To_Mede8er_2.0.0_Shizzl_yamj-2.6-SNAPSHOT-r2943_32bit_18Feb2012\temp\Jukebox\The.Usual.Suspects.(1995).jpg (The system cannot find the file specified)
   at com.moviejukebox.tools.FileTools.createFileInputStream(FileTools.java:421)
   at com.moviejukebox.tools.GraphicTools.loadJPEGImage(GraphicTools.java:89)
   at com.moviejukebox.MovieJukebox.createPoster(MovieJukebox.java:2455)
   at com.moviejukebox.MovieJukebox$7.call(MovieJukebox.java:1497)
   at com.moviejukebox.MovieJukebox$7.call(MovieJukebox.java:1486)
   at com.moviejukebox.tools.ThreadExecutor$ScheduledThread.run(ThreadExecutor.java:101)
EDIT:
turned off zone alarm firwall and re-ran again
...this time i got movie rip details....but no movie art?
got this error log
[14:38:03 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M/skin-user.properties', not found.
[14:38:03 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M\overlay.properties', not found.
thanks
« Last Edit: June 29, 2012, 03:39:30 pm by reevesy » Logged
the-osiris
« Reply #43 on: June 29, 2012, 03:41:15 pm »
Test your java from http://www.javatester.org/
is there any nfo files on your movie folder (The.Usual.Suspects.(1995) for example) ? if not, just create using notepad, then put this text into it http://www.imdb.com/title/tt0114814/ then save it with the same filename as movie file, but save as .nfo (instead of .txt) this will help scraping imdb metadata.
dont give up now, not yet  Smiley
by the way, this error is common and nothing to worry about Smiley
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
reevesy
« Reply #44 on: June 29, 2012, 04:52:07 pm »
thanks....again
ran java tester...got an error details stated 'Classnotfoundexception'
the saga continues!
Pages: 1 2 [3] 4   Go Up
