Pages: [1] 2 3 4   Go Down
Author Topic: Error on "Run YAMJ" action  (Read 5446 times)
francoisZA
B8a Tester - 1000X3D
« on: February 28, 2011, 10:36:52 am »
I get the following error when I hit the "Run YAMJ" tab. Any ideas?
Error occurred during initialization of VM
Could not create the Java virtual machine.
Could not reserve enough space for object heap
Zone 1: All HDMI to NAD
MED1000X3D 0.25TB 2.5"
PCH C-200 0.25TB 2.5" +BDRW
HTPC 4x2TB RAID5 + DAS 4x2TB RAID5 on USB3 + BDRW Win7 HaneWin NFS; HDMI->LG; SPDIF->NAD
SMC WGBR-14N2 Gbit Router + D-Link 2500U ADSL All on Cat6
NAD T765 HD2
LG 42" FHD LCD
Zone 2: HDMI to LCD
MED500X 1TB on Cat6 D-Link PowerLine
Samsung 32" FHD LCD
Zone 3: HDMI to LCD
PCH A-210 0.5TB on Cat6 D-Link PowerLine
Administr8or
Online Online
« Reply #1 on: February 28, 2011, 11:04:36 am »
Hi francoisZA
Pls try this
1. Right click "My Computer" and select "Properties"
2. Select "Advanced system serttings"
3. Select "Enviroment Variables"
4. Go to the window "System Variables"
5. Scroll down and find System Variable "QTJAVA"  and double click it
6. Make sure that the path looks like this "C:\Program Files\Java\jre6\lib\ext\QTJava.zip"
7. So in point 6. you want to put in the correct path to the file "QTJava.zip"
francoisZA
« Reply #2 on: February 28, 2011, 12:20:15 pm »
Hi Mede8er1,
Path is correct on my system.
NAD T765 HD2
LG 42" FHD LCD
Zone 2: HDMI to LCD
Samsung 32" FHD LCD
Zone 3: HDMI to LCD
« Reply #3 on: February 28, 2011, 12:29:37 pm »
Anthing to do with this:-
http://www.mede8erforum.com/index.php/topic,4737.msg32172.html#msg32172
francoisZA
« Reply #4 on: February 28, 2011, 01:28:06 pm »
Nope, only one Java.exe in bin directory.
NAD T765 HD2
LG 42" FHD LCD
Zone 2: HDMI to LCD
Samsung 32" FHD LCD
Zone 3: HDMI to LCD
« Reply #5 on: February 28, 2011, 01:46:49 pm »
The Google link refers to mutiple Java installs in different directorys.
francoisZA
« Reply #6 on: March 01, 2011, 06:54:11 am »
Yes, and as I said there is only one.
"...and so unless the java’s bin is the foremost in the path, one will bound to get the error. The error occurs because Java.exe or other Java executable expect some support files and directories to be found but obviously could not find it in Windows directory. Running the java.exe in its bin directory will not produce error because Windows will use  the current directory to which the file is run first before searching for it in the path..."
But it is...
NAD T765 HD2
LG 42" FHD LCD
Zone 2: HDMI to LCD
Samsung 32" FHD LCD
Zone 3: HDMI to LCD
reevesy
« Reply #7 on: June 24, 2012, 01:58:50 pm »
hi all
....yet another yamj problem!....get it working then a java update kills it  Angry
have followed the above posts but cant find any link to java in my 'system variables'
...can i set a path to it for yamj to work manually and if so how do i do it?
thanks
reevesy
« Reply #8 on: June 24, 2012, 02:12:17 pm »
well tried to manually make a path and copy and paste the 'path'
....did'nt work
reevesy
« Reply #9 on: June 25, 2012, 09:37:48 am »
can anyone help?
reevesy
« Reply #10 on: June 26, 2012, 11:39:36 am »
dont think java problems with yamj are uncommon.....can anyone help please
cheers
« Reply #11 on: June 26, 2012, 11:49:38 am »
I checked my variables in windows.
I see 2 variables:
QTJAVA with value C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
Also:
CLASSPATH with value: .;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
This is with the 32 bit version of java installed, using the 32 bit Y2M package on a win7 64bit system.
(yes you can use 32bit java and Y2M package on a 64bit system).
shizzl
« Reply #12 on: June 26, 2012, 05:31:49 pm »
try this:
1. Remove Java entirely, best with revo uninstaller will remove registry also
2. Download java http://www.java.com/en/download/manual.jsp
3.  Install
in MovieJukebox.sh and MovieJukebox.bat
try to rise the xms value
java -Xms256m -Xmx1024m
to java -Xms1024m -Xmx1024m
if thats not working reduce the values
to java -Xms512m -Xmx512m   or even lower.
MED1000X3D
reevesy
« Reply #13 on: June 26, 2012, 05:59:11 pm »
thanks for the replys
removed java using a tool earlier...different one from your recommendation i think
...re-installed..also re-installed yamj
i'm using win 7 32 bit and now have 2 paths in the user viables window
Class Path
C:\Program Files\Java\Ire 7|bin
and
Path
Now have 'could not reserve enough space for object heap' error
where do i go to in order to find 'MovieJukebox.sh and MovieJukebox.bat and to try and change the xms values
....cant find them?
thanks again
reevesy
« Reply #14 on: June 26, 2012, 06:05:47 pm »
well found a MovieJukebox in the yamj installation folder.....clicking on this just brings up a flash of a small 'Dos' type window which dissapears as quick as it comes up
..and the MovieJukebox.sh....click on that and windows says it has'nt the program to open up this file?
have to forgive me i'm a bit of a novice
thanks
Pages: [1] 2 3 4   Go Up
