Pages: 1 [2]   Go Down
Author Topic: [TIP] Creating a shortcut to your network shares  (Read 18883 times)
asenmmh
« Reply #15 on: February 12, 2010, 11:20:47 am »
 Huh
 I have rady to conect to my PC Network to my Mede8ER
but, when I Play the movie the mede8er must restart
So, i can't  play my movie from Network
What hapen?
Peter de Bruijn
Guest
« Reply #16 on: March 08, 2010, 12:54:35 am »
Here's the detail:
      o Go to Media Library > Network > 'My Shortcut'
      o Press MENU on the Remote & select ADD;
      o Select DETAIL (on the bottom right-hand corner of the dialogue box)
      o Type in a LABEL for the shortcut
      o Type in the USER NAME
      o Type in the PASSWORD
      o Type in the DOMAIN / WORKGROUP
      o Type in the SERVER (PC) NAME
      o Type in the IP ADDRESS
What user-id / pass word and what ip-adress do i use here?
Archer
« Reply #17 on: March 08, 2010, 01:34:07 am »
The IP addy of your server with the files you want to add the shortcut to. User/pass has to be to a valid account on the server that has access to the files in question.
Ron_P
« Reply #18 on: April 22, 2010, 04:10:11 pm »
Hi Folks,
I have a problem making a shortcut to my files.
The problem is that I can't use slashes to go to the next folder, they are blocked.
Is there someone that knows how to solve this?
Thanks!
Ron
Insomniac
Moder8or
« Reply #19 on: April 23, 2010, 05:00:55 pm »
Hi Ron,
You can only make a shortcut to a share - at this point one cannot create an entire shortcut path - slashes are disabled.
Mark Vleuten
« Reply #20 on: September 22, 2010, 09:30:58 pm »
Here's the detail:
Bello i'am using xp home edition. And using simple file sharing. In this case it is not possible to define à username and password....
What to do in this case?
Mark
« Reply #21 on: September 22, 2010, 10:03:15 pm »
Mark,
Have you tried to enter as username: guest
And leave password blank?
Mark Vleuten
« Reply #22 on: September 23, 2010, 09:50:22 am »
Hello Maasbommel,
Yes I did. (in my case 'Gast')
Mark
Freddy-M8
« Reply #23 on: September 29, 2010, 06:15:15 pm »
Hi Mark,
Guest at most pc's is turned off. (or should be)
You can make a new account like [mede8er] with a password.
On the PC-shares you can set the permissions.
At fristtime connect from m8r add the pc-hares to m8r-shares.
m8r remembers the credentials for next time
Fred
MED500X board 1073DD f/w v4beta4 loader 1026 -  Samsung HD203WI 2TB   (M8R formatted)
Audio:  Optical output > JVC RX-E112rsl - SPDIF Passthrough  / Nightmode OFF
Video: - HDMI output > LG 42" Plasma LG42PX3RVA
Wired Network: Cat 5e / fix IP / Router LynkSys WRT 54G
PC Q8200
Multiboot: Win 7 Ult. 64 bit /  Vista Business 32 bit / Win XP Pro SP3 32 bit .. + Norton360
Basil Plumley
« Reply #24 on: July 04, 2011, 10:10:27 pm »
First post so please be gentle... Roll Eyes
I have set up a shortcut to my nas and can see it and play files from it using the shortcut method - but for the life of me I can't get anything from the shortcut onto the video wall - the only way I can do this is to transfer the files onto the HDD in my 500x but they take an age to do (sometimes all night).
Also (slightly off topic), why does it take 4 or five times longer to rip a dvd to the HDD in my 500x than it does to rip the same film to my nas...?  If it didn't, I would rip directly to the HDD and bypass the nas altogether...
« Reply #25 on: July 04, 2011, 11:19:48 pm »
When you go to the shortcut link and then enter it, you will see the name of your shared nas volume.
You cannot map this to the videowall. Only folders BELOW this volume name can be linked.
So e.g make folders on that volume called Thriller, Animation etc.
Place your movies in subfolders of those genre folders, every movie in a separate folder.
Now make a shortcut link to the videowall by putting the cursor on one of those genre folders (e.g. Thriller) and selecting the videowall icon.
Basil Plumley
« Reply #26 on: July 06, 2011, 06:48:38 pm »
Thanks for that - I think I've completley set my network up wrong in the first instance... Roll Eyes
I'm using a Seagate GoFlex Home NAS and when I add that to my shortcuts, it drops down to show the backup, personal and public drives...when I click on the public drive I can see and play the files on it - but can't get them to attach to the video wall - I get the message "NOT AVAILABLE" at the bottom of the screen.
« Reply #27 on: July 06, 2011, 06:58:30 pm »
Have you tried to setup a network shotcut in the shortcut menu?
By pressing menu, filling in ip and logon?
If you are using no user names you might try Everyone or Guest as username and leave password blank.
Save this shortcut.
Then browse to your nas by entering this made networks shortcut and try to make a shortcut on a folder.
Then check on the video wall if it still gives the same error.
Basil Plumley
« Reply #28 on: July 06, 2011, 07:37:00 pm »
Save this shortcut.
Thanks for your help but I think I sussed it in between you and I posting...I hadn't switched on "FTP" on the mede8er - just tried it and was able to get something from my NAS onto the video wall and connect to it - even though it was an empty folder.
The video wall is important to me as without it, in a family of five, I'll be the only person who uses it and the main aim (to get rid of the 400 odd DVD boxes out of the living space) would not be achieved...
Pages: 1 [2]   Go Up
