Pages: [1] 2   Go Down
Author Topic: [TIP] Creating a shortcut to your network shares  (Read 18549 times)
Insomniac
Moder8or
« on: September 18, 2009, 06:56:48 pm »
Should you be having difficulty seeing your network shares, you can create a shortcut as follows:
      o Go to Media Library > Network > 'My Shortcut'
      o Press MENU on the Remote & select ADD;
      o Type in your User Name, Password and IP Address
      OR
      o Select DETAIL
      o Type in a LABEL for the shortcut
      o Type in the USER NAME
      o Type in the PASSWORD
      o Type in the DOMAIN / WORKGROUP
      o Type in the SERVER (PC) NAME
      o Type in the IP ADDRESS
You will cut out a lot of the navigation nonsense and go straight into your shares.
« Last Edit: October 16, 2009, 09:28:54 am by Insomniac » Logged
luppio
« Reply #1 on: November 15, 2009, 06:53:58 pm »
one lamers question: how can I type login and pw from remote? (is there any virtual KB possibility?
Insomniac
Moder8or
« Reply #2 on: November 15, 2009, 07:06:16 pm »
Press enter on the login field and an on-screen virtual keyboard appears.
Use navigation buttons and ENTER to select the letters and select the OK button to finish.
dikkiedirk
« Reply #3 on: November 29, 2009, 01:04:20 pm »
Another newbie question:
Will this also work for NFS shares? What password and loginname should be used?
Insomniac
Moder8or
« Reply #4 on: November 29, 2009, 01:50:48 pm »
Hi dikkiedirk,
For NFS shares you use the NFS source option from the Media Library source list - you don't use these types of shortcuts discussed here for NFS shares at this point.
It however is on the cards for future integration into the Shortcuts.
j.lievens
« Reply #5 on: December 01, 2009, 02:21:58 pm »
If been trying to get labelled shortcuts in my mede8er but I did not succeed. Where can I find DETAIL?
Insomniac
Moder8or
« Reply #6 on: December 01, 2009, 04:39:47 pm »
Here's the detail:
      o Select DETAIL (on the bottom right-hand corner of the dialogue box)
Archer
« Reply #7 on: December 26, 2009, 09:07:48 pm »
This might be a newb questions, but how do I do this with hidden shares? (Those ending with $ on a windows network) There doesn't seem to be an option to type in the shared folder name manually.
Thanks!
Insomniac
Moder8or
« Reply #8 on: December 26, 2009, 09:45:23 pm »
Hmmmm... and what exactly would you be hiding in these 'admin' shares that you don't even want people to see that they exist?  Tongue
This is currently not possibleas admin shares have been masked and hidden (it becomes a bit cluttered if you see all these C$, D$, etc by default), but there is a future project to save full paths as shortcuts and not just shared PCs. This will be placed under consideration when this project is commenced.
« Last Edit: December 26, 2009, 09:50:00 pm by Insomniac » Logged
Archer
« Reply #9 on: December 26, 2009, 10:04:08 pm »
LOL, I actually use the $ for 'other' things than my admin shares... and not just pron! ;-)
I let my neighbours use my wireless so they have access to my media downloads, but I would prefer they not have access or visibility to my family pics and home videos folders - although I still want to share them across the network for my own viewing. For now I am using an NFS (haneWIN) for my personal network shares, and have mapped my public ones to my neighbours via the standard workgroup shares.
To that end, I noticed when browsing the network that the default workgroup name for the Mede8er is workgroup... is there any way to change that? I didn't see the option in the network settings area.
Thanks!
Insomniac
Moder8or
« Reply #10 on: December 26, 2009, 11:53:08 pm »
Not via the GUI, no - it's on the feature request list somewhere.
There is a hacky method described here but I am not in a position to assist with this...
kienah
« Reply #11 on: January 21, 2010, 03:08:59 pm »
Noob Question
I can see both my Pc@s on the network, and then i see all the drives, but once i choose a drive to goto then it asks for user name, password???  What and where do i get that from
Im using Windows 7
Please take pity on a noob....................LOL
« Reply #12 on: January 21, 2010, 10:56:19 pm »
This are just simple basic filesharing questions, please first start reading the mede8er beginners guide and look at the links in the faq section of it....
kenmeg
« Reply #13 on: February 11, 2010, 11:07:31 am »
I find this device is a piece of rubbish as a NAS. Everytime you want to do something you have to connect it to a TV or a Monitor, why doesnt it have a web browser? Just an expensive toy to watch Video, with nas as a joke.
There are alot of better devices out there that and are cheaper that at least allows one to connect via a web interface once you have given it a IP. Angry
Took me 3 attemps to get the HD1 icon to appear on the netwrork, using the latest firmware.
Way to go.
« Reply #14 on: February 11, 2010, 09:46:15 pm »
Hi kenmeg,
Just some joking...  Grin
Maybe you have the wrong expectation...
The mede8er is build to play media files, it is a mediaplayer not a NAS.  Wink
And just look arround,  you will find out that the mede8er is not really expensive for what it is capable of.
Just my 2 cents...
Pages: [1] 2   Go Up
