Pages: 1 ... 3 4 [5] 6 7 ... 9   Go Down
Author Topic: Mede8erRemote app for Android phone  (Read 40022 times)
cdw
« Reply #60 on: November 26, 2011, 08:52:46 pm »
Yes it is and with other app's like "FILE EXPERT" i can see and browse trough the mede8ter, so it is not a configuration problem or something like that. My son hase a Sony Ericson phone and it workt 1 time with his phone further it did not worked any more.
Feersum
« Reply #61 on: December 05, 2011, 01:23:23 am »
No good on either of my devices... Freezes on first button pressed... Using Samsung Galaxy S2 (Android 2.3.3) and Samsung Galaxy Tab 10.1 (GB 3. 2)
« Reply #62 on: December 05, 2011, 09:20:47 am »
Did you set the IP number of your mede8er with the menu button first before starting to use it?
peerke1947
« Reply #63 on: December 14, 2011, 12:07:24 pm »
Wow i love these kind of apps , gonna try it right away  thanks very much Grin Grin Grin Grin
peerke1947
« Reply #64 on: December 14, 2011, 12:19:16 pm »
I have a problem, how do i get the app  on my phone HuhHuh?
« Reply #65 on: December 14, 2011, 12:49:12 pm »
It's a network app that assumes you have a phone which networks..and hence through your own network can access the internet to download it.
peerke1947
« Reply #66 on: December 14, 2011, 02:22:14 pm »
Yes i understand that i have a Galaxy S II and downloaded the app to my downloadfolder when i try to change the extention i can't get rid of the JPG extension i did try it several times and when i change the name in mede8er.apk and save it
the system put's every time the jpg extension behind it  nd then it looks like this
How do i get rid of the JPG HuhHuhHuhHuhHuhHuh
Skylinc
B8a Tester - 1000X3D
« Reply #67 on: December 14, 2011, 02:42:45 pm »
Peerke1947, you cannot use the built in file browser. You will need to download a 'better' one from Market. Alternatively, if you can access the phone's contents from your PC, you can rename the file there.
Audio: HDMI > LG 42LW4500
peerke1947
« Reply #68 on: December 14, 2011, 02:47:37 pm »
Yep i have the file from this forum named mede8erremote.apk.jpg downloaded to my computer at home when i try to change the extention in mede8er.apk it won't work because the pc still put's the jpg extension behind it when i look in propertys it say's that it is a jpeg afbeelding and i can't change that
« Reply #69 on: December 14, 2011, 02:56:25 pm »
You have to unhide known extensions in windows View..and then expose the extension. Rename will not work until then.
Hide them again whe your finished..
peerke1947
« Reply #70 on: December 14, 2011, 03:14:04 pm »
It's working perfectly  thanks very much for the advise !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
stanleywijaya
« Reply #71 on: December 14, 2011, 04:50:55 pm »
I used this app already, it works fine but.... can i turn my med500x2 device on/off with this app?
« Reply #72 on: December 14, 2011, 05:18:38 pm »
No you cannot. Reason: you can only connect when network is up.....
« Reply #73 on: December 14, 2011, 05:57:13 pm »
...at best...it could turn the Med off.  The Med2key only has a Power Off option...for a similer reason as Maasbommel said...nothing is reading the keyboard when it's off..so it can't be used to turn it on.
demonrecords
WWW
« Reply #74 on: December 14, 2011, 09:17:15 pm »
What's the purpose of this when you already have a remote control??
Why do you keep on watching the porno after you came?
Pages: 1 ... 3 4 [5] 6 7 ... 9   Go Up
