Author Topic: Mede8erRemote app for Android phone  (Read 224700 times)
Re: Mede8erRemote app for Android phone
« Reply #30 on: April 13, 2011, 05:22:22 AM »
Doesnt work on my HTC desire running 2.2  :-[ get the message - 'Activity Mede8erRemote (in application Mede8erRemote) is not responding' ?
Did you set the proper ip address (by pressing the left lower button on your phone when the application is started?
Offline pau131g
« Reply #31 on: April 13, 2011, 08:30:29 PM »
Yip put in IP address, it seems to only when i try and touch any of the functions, i can toggle between the top 4 icons but as soon as i touch a function it all freezes and i get the error.
When i select 'Wait' instead of 'Force close' i can then select the 4 icons at the top again.
Offline ChillyCat
« Reply #32 on: April 13, 2011, 09:45:05 PM »
Try the left button on the bottom of your phone.
Gracias Amigo.....and so it was   :-*
Why is it, i'm the only one asking ?  Am I the only member here approaching 60 ?
DroidX = wurks jes fine
Offline kashel
« Reply #33 on: April 14, 2011, 07:58:08 PM »
thnx man
works great
to bad that this app isnt available on the market store.
 8) 8) 8)
Offline PervertedMonk
« Reply #34 on: June 19, 2011, 07:19:51 AM »
Great job!! Installed + working on my Xperia X10i running Stock 2.1 Firmware.
Offline SjoerdV
« Reply #35 on: July 07, 2011, 08:34:25 PM »
Thank you, works great!
Offline djagerif
« Reply #36 on: July 21, 2011, 11:41:58 AM »
I just installed mine on HTC Desire and ran it 'offline'. I am not at home to test it properly but I suspect the application is trying indefinitely to connect to my Mede8er and then just hangs.
Could you add a check to see if you are on the local wireless LAN and only connect then? If you have an Internet IP/hostname going through a firewall this wouldn't be a problem. I am suggesting that the APP looks at the local LAN first, then the Internet and if it still can't connect within 'reasonable time' give an error and exits.
I am however very keen on the performance and will be testing it tonight. My Web access, using IE, is very slow and doesn't work very well to Mede8er. Firefox is a lot better.
Ingo
Offline Sebass
« Reply #37 on: July 26, 2011, 03:20:14 PM »
Works great on desire 2.2
thanks!
Offline a35077
« Reply #38 on: August 09, 2011, 09:04:46 PM »
Thank, works great on an Android 2.1 tablet.
Offline tachita_
« Reply #39 on: August 10, 2011, 02:52:51 PM »
is even greater on android 2.3.5  ;)
Offline stalensnuitje
« Reply #40 on: August 19, 2011, 08:12:57 AM »
Installing went flawlessly on Nexus S (2.3.4), I'll test the app later this weekend (probably on different ROMs as well ;))
Offline Conadude
« Reply #41 on: August 19, 2011, 03:49:05 PM »
Sweet Dude.
Its the shiznit.
AOK on Android 2.2. HTC Desire. ;D
Offline reinder
« Reply #42 on: August 31, 2011, 06:37:28 AM »
Grait job I could get it to work on my HTC. I am looking for a keybord so I can typ. But I think I will have to wait for the officiel keyboard to come out.
Offline Mpking
« Reply #43 on: September 20, 2011, 05:41:16 PM »
thx man i just installed the program on my cellphone and it works like a charm i hope you continue on this software thx  ;D
Offline Martin_S
  • 500X2 it aint it just yet, if it doesnt haveNZBGET
« Reply #44 on: September 24, 2011, 09:51:03 PM »
Nice!
ill try it on my poor man's Ipad ( yarvik)
« Last Edit: September 29, 2011, 05:40:06 AM by Martin_S »
MED500X2 it ain't IT just yet,when it doesn't have NZBGET
