Author Topic: Mede8erRemote app for Android phone  (Read 224703 times)
Offline stanzo
Re: Mede8erRemote app for Android phone
« Reply #15 on: February 18, 2011, 07:08:34 PM »
Works fantastically on HTC Desire!
Best app for me do far. Thank you.
Offline alexander
« Reply #16 on: March 03, 2011, 06:37:59 PM »
works fine, execpt navigation (forward , backward ) while playing a movie is not working on a htc desire !
navigation in the menu works fine !
Offline molles
« Reply #17 on: March 15, 2011, 11:10:37 AM »
How can rename the file ???
Offline ChillyCat
« Reply #18 on: March 30, 2011, 12:46:14 AM »
Call me whatever.....but I can't find where to enter the IP     ???
« Reply #19 on: March 30, 2011, 06:04:42 AM »
Try the left button on the bottom of your phone.
Offline TheDJ
« Reply #20 on: April 07, 2011, 07:11:11 AM »
Great App!
Works like a charm on my Galaxy S I9000..
Should this app work on the Playon!HD also? The Playon has the Remote web, but with the original Remote layout..
« Reply #21 on: April 07, 2011, 11:43:43 AM »
Give it a try.....
Here we can only say something about mede8er....
Offline Thatch
« Reply #22 on: April 08, 2011, 11:54:52 AM »
I get a Parser error when i try to install it.. I have  HTC Hero running Android 2.1 (update 1)
Someone understands this/
Offline tachita_
« Reply #23 on: April 08, 2011, 08:31:41 PM »
there are some variants :
the app apckage was compiled for android version higher then yours ....
or is signature failures ..
did you mark the checkbox  - install unknown sources - from settings / aplications ?
try to redownload the app
or use adb and push it to filesystem ....
for adb use gooogle .... there are some files to download  and need attention and  etc etc etc
Offline peterbakker
« Reply #24 on: April 12, 2011, 02:18:59 PM »
I get the same error. HTC Desire, android version 2.2
« Reply #25 on: April 12, 2011, 03:08:25 PM »
My Samsung Galaxy S has 2.2.1 and no problems.
Offline tachita_
« Reply #26 on: April 12, 2011, 04:44:26 PM »
then very pprobable is because is the stock rom and some of you made the update with latest sources from official rom without understanding what imply such this . there are some security verification for certain certificates files ... last update didn't bring nothing to improve the overall android system speed or functionality....
solution is to downgrade or root.....  more sure is to use root and to forget about sense UI or other crap ... you'll discover and have only benefits
i speak here only for HTC users
Offline sjweemie
« Reply #27 on: April 12, 2011, 05:39:28 PM »
bought an android pad. wil try soon:) hope that it wil be possible to tsee the movie wall also and then select what movie i want to see.
thnx great job
Offline pau131g
« Reply #28 on: April 12, 2011, 10:09:17 PM »
Doesnt work on my HTC desire running 2.2  :-[ get the message - 'Activity Mede8erRemote (in application Mede8erRemote) is not responding' ?
Offline tachita_
« Reply #29 on: April 13, 2011, 12:19:17 AM »
www.upload-ro.ro/download.php?file=498758a303471c9a101bc558c5b73e3d
is the same app, but a fresh one.
if someone try it and can confirm if work or not .
just to eliminate some hunts .....
