Pages: 1 ... 6 7 [8] 9   Go Down
Author Topic: Mede8erRemote app for Android phone  (Read 40017 times)
3kb6vs9b1
media eater
« Reply #105 on: June 21, 2012, 11:17:15 pm »
Images are quite hairy on tablet. Any plans to go for  HD?
haegemonia
« Reply #106 on: June 22, 2012, 10:34:51 am »
press left touch button on the bottom of your phone.
On galaxy S3 working fine ,thanks  Grin
« Last Edit: June 22, 2012, 10:52:48 am by haegemonia » Logged
esterado
« Reply #107 on: June 24, 2012, 10:46:22 am »
Works on my samsung i 5510 but not everything. Sad
The skip and the forward are not working.
But still an great app
esterado
wave1401
« Reply #108 on: August 17, 2012, 05:31:56 pm »
Not working on galaxy tab 10.1. Any chance you can do an update.  Grin  Either way, thanks for doing the effort.
Fcpiek
« Reply #109 on: September 05, 2012, 09:12:26 pm »
Sounds nice to have! But since I am only used to the PLAY market for Android, I have no idea how to get this from my PC's download directory to my SIII and then make it work.
Since some people already have it installed it can not be that difficult, I just like to know how to do it.
thanks,
Fred
Mike42
B8a Tester - 1000X3D
« Reply #110 on: September 06, 2012, 12:00:51 am »
thanks,
Fred
- download the file http://www.mede8erforum.com/index.php?action=dlattach;topic=4624.0;attach=1376
  on the very first page of this thread
- remove the extention ".jpg"
- your now left with the android app "mede8erRemote.apk"
- connect your phone/tab with usb to your pc/laptop and make the connection
- copy the mede8erRemote.apk to the download folder on your phone/tab
- use your file manager on your phone/tab to navigate to the mede8erRemote.apk file (in the download folder)
- when found select the file and select install the mede8erRemote.apk
hope this helps,
Greets Mike42  Wink
Mede8er : MED1000X3D
Network: Wired CAT5
Display device: HDMI to Samsung LE32B650T2WXXN, LCD, HD TV
Audio connection: optical dig. to Sony ht-sl5 Home theater system
additional equipment:
Switch sitecom N118 to MED1000X3D, Samsung tv and PS3
Archos 101 internet tablet for DMC
Fcpiek
« Reply #111 on: September 06, 2012, 12:42:16 pm »
It works!
After all it was simple. Getting the .jpg extension off of it was almost the hardest, as I needed to go to DOS te rename the file. Without all the info of what to do and where to put it etc.I would not have been ble to do it. Thanks Mike!
cornedp
X2 Skin Designer
« Reply #112 on: September 06, 2012, 01:47:53 pm »
Tx for this, will give it a try tonight after work
WilcoD
« Reply #113 on: October 01, 2012, 02:18:16 am »
Doesn't work on Samsung Galaxy Tab 2
Can't enter IPadres in the options
« Reply #114 on: October 01, 2012, 11:08:19 am »
Can you cut/paste into the field instead?
Riffer
« Reply #115 on: October 05, 2012, 10:20:36 pm »
why did you not put it in the market?
Product & firmware version: Mede8er MED500X f/w v2.0.2
Video: Samsung LE32B650
Video setting: PAL, 24Hz ON, 16:9
Media Source: Windows XP SP3 SMB  and/or FTP > Wired Network
Hard Drive: Samsung F3 HD203WI, formatted using Mede8er old Firmware, then upgrade to 2.0.2
Gutterboy
« Reply #116 on: November 06, 2012, 02:46:57 pm »
This app does not work on the Sony Xperia Neo.
That [CENSORED]   Embarrassed
Any change for an update?   Huh
Product & firmware version: Mede8er MED500X2 f/w v2.0.8 beta
Audio: Optical output > Yamaha RXV365 HD Audio
Video: HDMI output > LG 47" LED LG47LE5300
Video setting: 1080p 60Hz,24Hz OFF,16:9
Media Source: External HHD Western Digital USB3
« Reply #117 on: November 06, 2012, 09:38:25 pm »
Confirm that the default Sanji Remote webpage appears using your phone browser.
Gutterboy
« Reply #118 on: December 03, 2012, 10:21:57 am »
 Huh sorry dont really understand what you are asking but the app opens up like normal with the buttons like the remote.
then I insert my mede8er ip address that is 192.168.0.10,  but the buttons on the phone does not work.
my wifi is always on as I use it to connect to my pc via the router.
« Reply #119 on: December 03, 2012, 11:24:21 am »
The android app  won't work if the internally hosted webpage remote doesn't appear when tried.
Pages: 1 ... 6 7 [8] 9   Go Up
