Pages: [1] 2 3 ... 9   Go Down
Author Topic: Mede8erRemote app for Android phone  (Read 41680 times)
Cuball
« on: February 16, 2011, 09:42:47 pm »
Hello,
I've created an app for Android phone, the app allows you to use your phone as remote.  It's based on the HTTP remote embedded in the mede8er.
Before using the remote you need to set the IP address of your mede8er.  This is my first app ever, so don't except too much of it :-).  I runs on my Samsung Galaxy 3 phone but should run on any Android 2.1 phone. The app does not support landscape mode..
Below is the app.
Cuball
ps: i've upload the app as .jpg extension (.apk is not allow, so you need to rename the file)
« Reply #1 on: February 16, 2011, 09:49:02 pm »
Now you need to get an Android PAD which can display all the Movie Folder images to select what to play and you can make the Ipad owners sick with envy.
Cuball
« Reply #2 on: February 16, 2011, 09:52:59 pm »
if the mede8er developers would provide an API for that,  it would be easy to create app with that kind of functionality..
« Reply #3 on: February 16, 2011, 09:59:47 pm »
... and it would be nice if they sent you an Android Pad to test it with! Grin
« Reply #4 on: February 16, 2011, 10:11:58 pm »
Great job!
Just tried it on my Samsung Galaxy S, Runs very smooth and responds good.
Administr8or
« Reply #5 on: February 16, 2011, 10:21:29 pm »
Hi Cuball
Great work and very well done.
« Reply #6 on: February 16, 2011, 10:26:41 pm »
Looks like you'll have to extend the API and keep him busy!  You could use the touch screen to move through the movies folder images and select which one to play. I was thinking with the images on the phone, not the TV.
« Last Edit: February 16, 2011, 10:31:18 pm by jer1956 » Logged
Cuball
« Reply #7 on: February 17, 2011, 12:14:08 pm »
You're welcome :-)
Hope you enjoy it.
« Reply #8 on: February 17, 2011, 12:21:01 pm »
I think they should move this to the offical Software Downloads section so more people find it!
Cuball
« Reply #9 on: February 17, 2011, 01:33:32 pm »
The normal procedure is to publish the application to the Android market.  That way everybody can find the app via the Market app installed on the phone.
I don't know the details (technical, financial, geographical, ..) about publishing apps but there's a registration fee of $25 before you can post an app.
« Reply #10 on: February 17, 2011, 01:37:51 pm »
The issue is that posts in these sections of the forum drift off the current pages and into oblivion over time. Some sections don't change as they are less for discussion, and more for fixed information. Those include the Software Downloads and Tips section. So with the arriival of the remote interface they could add a  whole new section of software apps to the primary sticky list, and link  that to  your post in that section.
tachita_
Senior Member
« Reply #11 on: February 17, 2011, 05:46:58 pm »
@ cuball , great work with your app and very stable compared with my bookmarked remote.
i'll hope you will get the API for further development  Wink
good job
tramal
« Reply #12 on: February 18, 2011, 01:20:19 pm »
Great job cuball!
I just have the problem that pressing a button on the app-remote is like pressing that button 3 times. E.g. pressing "left" or "right" in the menu will move 3 icons to the left or right. Same with "enter" or any other button.
Maybe this is specific to my phone since I am the only one here having this problem. I am running your App on a Nexus One with Froyo 2.2.2 (official firmware).
Would be great if you could help me!
Thanx
tramal
tachita_
Senior Member
« Reply #13 on: February 18, 2011, 03:51:09 pm »
Great job cuball!
Thanx
tramal
maybe is time to jump in Gingerbread  Smiley
« Reply #14 on: February 18, 2011, 07:00:16 pm »
Great job cuball!
Thanx
tramal
I am running on Samsung Galaxy S with 2.2.1 official Samsung release. Don't have this issue. It is running very smooth and responding better then the standard web interface.
Pages: [1] 2 3 ... 9   Go Up
