runefire
Offline
« Reply #15 on: December 19, 2009, 01:15:54 pm » |
streaming HD media via 15MByte/sec sounds very doubtfull.
exactly, hence me trying to find out beforehand what the average rated speed for the wireless dongle and an equally compatible 802.11n accesspoint. the MAJOR selling point for me was the 802.11n compatible dongle....  also, if 5MByte/sec is the norm in 100mbit LAN speed, will the mede8er crew be addressing this?
mysticc
Full Member
Offline
« Reply #16 on: December 19, 2009, 01:48:20 pm » |
@runefire
Do you mind correcting your quote?
It was YOU having doubts. I know there is no need to have doubts 15 MByte/s might not be enough for streaming HD, as it is far more than needed.
V3.0 Beta MED500X with internal HD 250G 100Mbit Networked with CAT5 to AVM Fritz 7220 Networkshare mainly on Win2003 Server, sometimes on Windows7 x64 Ultimate Connected via Component to LCD and HDMI to projector. AVR: Denon-3805 Projector: Sony HW-10 LCD: Viewpia 37 Blu-Ray-Player: LG BD 370
Ice_Black
Offline
« Reply #17 on: December 19, 2009, 10:54:45 pm » |
Is 100 mbps enough for full HD streaming via network wire.
mysticc
Full Member
Offline
« Reply #18 on: December 19, 2009, 11:06:14 pm » |
If not there would be many reports all Mediaplayers out there not being able to do what they are sold for. So, yes, far enough.
Offline
« Reply #19 on: March 20, 2010, 07:10:28 pm » |
Unfortuantely lan standards for error prone methods (wifi and mains) don't quote throughput speeds, with the overhead of error correction removed. It's bit like TV. We have a 625 line standard. Due to the overhead of CRT line and field fly back only 576 can be used for actual video. So with wi-fi and mains lan you can right off half due to large amounts of error correction required. The other problem is wifi and mains are installation dependent. Your wonderful 300 mps wireless-N system may actually be running at something much lower, even before you take error correction into consideration.
I don't have wireless-N, only Hi-speed 125. Carefully testing channls I can get a reliable 125 connection which dosn't drop down to something slower. Even then I can't expect much more than 33 mps. That is fine for HD. It's simple to test anyway. If it takes 30mins to copy 1 hour of video to the hard drive, then you have twice the bandwidth required to stream the same file. If it takes 1 hour to copy 30mins of video then you have real problems!
gusan
Offline
« Reply #20 on: March 22, 2010, 09:34:24 pm » |
I have a w7 64bit and a quad processor and lots of ram and gb network connected to the player by cable throu a modern switch with 8 ports and a wireless-N. (i think it is wrong configured but it works and i welcomme better conf tips on that) Intenet is 100/20mb/s fiber connected into the W-N, from the W-N cable to a switch, and 2nd cable directly to Mediaplayer, from Switch to PC1 and PC2 ..finally i use the W-N only for minipc w less. I get between 2,5 and max 4,65mb/s and i have a new 1tb disk on the player, for now i transfer the files but wish to play/stream directly from PC. What should my transfer speed be? Is 2,5-5mb/s enough for BR 1080p streaming? Regards
« Last Edit: March 22, 2010, 09:44:48 pm by gusan »
niniz
Offline
« Reply #21 on: May 11, 2010, 11:20:21 pm » |
I do not understand..? Why am i only getting 4.77mb/s max when i got 8mb/s with my xbox from 2001?
niniz
Offline
« Reply #22 on: May 13, 2010, 04:18:50 pm » |
someone?
Offline
« Reply #23 on: May 13, 2010, 05:03:58 pm » |
Just search around, this kind of questions have been answered already several times.....
Please check the Mede8er Beginners GuideMede8er FW 3.0.4 with HD103UJ 1TB with Linksys WET610N Wifi bridge Mede8er FW 3.0.4 with HD502H Lan Windows 7 64 Ultimate on Q6600 quadcore PC Synology DS409slim DSM 2.3-1157 Netgear wndr3700 N FW V1.0.4.55 Samsung 52" LCD LE52A756R1M FW 1013.1 (HDMI to Mede8er) Panasonic SA-PTX5
sunil1234
Offline
« Reply #24 on: May 14, 2010, 05:42:10 pm » |
so much issue over copy speed wow  the mede8er is not a copy device, it is a media player and as long as it does that first and foremost please accept 5mb/s copy speed to transfer files for exmaple over homeplug network in my setup. Thus i transfer around 35gb this morning in 2 something hours. No big deal, whilst this was copying i was able to play 14gb 1080p from internal hard drive no problem  Copy speed is not streaming speed
Hotblack
Offline
« Reply #25 on: June 17, 2010, 11:30:51 pm » |
Furthermore a good copy manager will permit you to pause, add, remove, promote, demote, etc the files being copied, plus provide logs and set default actions if similar files already exist such as overwrite, skip, rename, etc... The error handling is also generally better, such as when either a source or destination drive is lost or intermittent.
I have personally always been happy with SuperCopier, simply because it was the first one I came across that did all I needed...
I'm looking for a copier that can cope with an intermittent line as I'm trying to copy via the house electrical ring main using Devolo homeplug adapters. I'm assuming my problem with copying is caused by the Devolo adapters as I've done a search and I can't find anybody else getting error messages like “The destination folder is no longer available” (Terecopy) and “WriteFile (The semaphore timeout period has expired.121) (Fastcopy). I had a look at SuperCopier but I couldn't work out where to start as I'm not that techie and would kill for a copy program that had a nice GUI. I was hoping to be able to copy 4 films across in one go but they all seem to be >point at source file >point at destination file, which is really only for one file at a time. Are there any other programs that can cope with a flaky line and won't just fail as Terecopy and FastCopy have done? IE with pretty buttons and clear instructions on what to do rather than these very basic looking programs that kind of assume that you know what you are doing already? Thanks
Hotblack
Offline
« Reply #26 on: June 19, 2010, 08:37:26 am » |
Fair enough, back to the USB cable then
Offline
« Reply #27 on: June 19, 2010, 09:59:25 am » |
Or maybe just consider to use a lan cable. Power plugs can work ok, but can also give a lot of trouble in bandwith.
Hotblack
Offline
« Reply #28 on: June 19, 2010, 02:24:15 pm » |
I've been using them for a couple of years now and for surfing and Vuzing they do the job perfectly. I've only recently purchased the Mede8er and its some distance from the switch so the power plugs would be ideal if I didn't keep getting these drop out errors. Having said that, It's quite happy to copy across smaller files (50mb) and I even managed to copy a 1.4Gb file across (with Fast Copy) but that was on the 4th attempt. Obviously running a long network cable is on the list of options but if I could find a copy program that can cope with intermittent lines (like some download programs do) then that would save me running the cable. I'm not too worried about super fast copy speeds as I've always got something else I can be doing whilst it's doing it's thang. I'm not familiar with FTP, is that something I should be looking into as an alternative option for copying? I'm taking up space here in the tips and tutorial section, maybe I should move this off to another part of the forum? Thanks for any advice.
Offline
« Reply #29 on: June 19, 2010, 11:22:13 pm » |
Hi Hotblack,
Yes, moving your post to the Technical Issues section would be better. You might consider to configure to use FTP, use Core FTP Lite, its free and works very well.
This program has some resume function and you can try to configure some longer time out values because of your fluctuating network connection. It might work....
regards, Maasbommel
