Author Topic: Ever had a problem with Yamj not processing your own artwork for films?  (Read 1866 times)
Offline fallex
I had annoying problems with one particular film (A TV Movie released
on DVD)that was causing me to loose what little hair I have left and
could not seem to find a fix for.
After much headscratching I worked out a solution that worked for me,
there may be simpler ways but as I said i could,nt find one.
if you navigate to http://www.mede8erforum.com/index.php/topic,4485.0.html
you,ll find the way I fixed it.
Did,nt want to post twice but after posting in graphic downloads I thought
the article might be a useful tip for some other users.
Apologies to admin if you see fit to delete this post.
