Author Topic: Beginners Guide: How To Make Internet Radio Station "PLS" Files  (Read 19362 times)
Firmware version v4 supports .pls Radio Station shortcuts files. We have prepared a simple User Guide on how to make these simple shortcut files suitable for playing back in the Mede8er
http://www.mede8er.org/artwork/temp/Mede8er_Making_pls_guide.pdf
« Last Edit: February 01, 2011, 01:39:07 pm by Mede8er1 »
Dutch Radio Station - "PLS" File list
« Reply #1 on: February 01, 2011, 08:17:45 am »
Dutch Radio Station .pls update attached
63 Stations
Offline jwkramer
Re: Beginners Guide: How To Make Internet Radio Station "PLS" Files
« Reply #2 on: February 03, 2011, 10:52:55 am »
Hallo,
Weet iemand hoe ik internet radio kan instellen met een zender die buiten de lijst worden gepresenteerd?
IP adressen invoeren lukt me niet...
Ik zie alleen maar Duitse Schlager zenders...
Bv. Radio 10 gold disco classics?
Thx
Offline stayfunkey
  • StayFunKey
    • Kixxx Development
« Reply #3 on: February 03, 2011, 11:53:08 am »
just look on the net for the radiostation if it has a pls file for you to download.
Save it on your (internal) hd and try to play it with the mede8er.
If it doesn't work try to edit the file with notepad
see this topic
http://www.mede8erforum.com/index.php/topic,4319.15.html
Succes
Stayfunkey
Mede8er FW 4.04  (Shizzl mod) no HardDisk
by LAN Sitecom WL575 router
Windows 7 64bit on Q9550 quadcore PC
Sony KDL-40w5500
Sony STR-DB780 AV receiver / Home Cinema set
Logitec Harmony One
Offline Hixxer
« Reply #4 on: July 13, 2011, 07:31:53 am »
Does this work for the 400?
If so, do you just create a "PLS" folder in one of your shares?
« Reply #5 on: July 13, 2011, 07:42:55 am »
Yes, this work for the 400X and you can place .pls files on a share folder.
