Author Topic: scrolling on movie wall  (Read 585 times)
snap
« on: January 28, 2011, 11:16:27 am »
hi there,
When displaying titles on the movie wall, titles are sorted vertically then horizontally. So the 1st title is at (x,y) 1,1. 2nd title is at (1,2) 3rd is at (2,1) etc.
When the cursor is on 1,1 I click the down button on the remote and cursor jumps to 1,2. When I click the down button again the cursor should go to 2,1 (in the sort sequence). Instead the cursor does nothing and stays where it is (at 1,2).
Can this be considered for future updates?
cheers!
snap
Product & firmware version: Mede8er MED500X f/w v4.0.5
Audio: analogue audio out
Video: composite video out (CRT television)
Video setting: PAL, pan-scan 4:3
Hard Drive: purchased with 1TB, formatted using Mede8er setup
Network: LAN with DHCP
WiFi: USB WiFi dongle purchased with unit
stayfunkey
StayFunKey
WWW
« Reply #1 on: January 28, 2011, 11:25:19 am »
I also saw something like this on the first level of the videowall.
If you have for instance 7 genres it has 4 icons on the top row and three on the bottom row.
If you select the last one on the top row and you want to go to the last one on the bottom row
you probably think you can press the down button but you can't!  Sad it does nothing,
you have to press left and down to go there.
This only happens ofcourse if the top row has one genre more then the bottom.
Bit annoying!
S
Mede8er FW 4.04  (Shizzl mod) no HardDisk
by LAN Sitecom WL575 router
Windows 7 64bit on Q9550 quadcore PC
Sony KDL-40w5500
Sony STR-DB780 AV receiver / Home Cinema set
Logitec Harmony One
Lord-D
« Reply #2 on: January 28, 2011, 11:33:55 am »
I also don't like the sorting.
It makes no sense ordering
1 3 5 7 9
2 4 6 8 10
Domino1999
Senior Member
« Reply #3 on: January 28, 2011, 03:02:47 pm »
I think it's a matter ot personal preference. I don't mind the existing display order of the items on the wall, but maybe it would be nice to have an option to switch it one way or the other.
Mede8er model: MED500X
Board: 1073DD
Bootloader: 0000.0202.1026
Firmware: V4.04 INC_HD Audio
Internal HDD: WD20EADS 3.5" Caviar Green 2TB SATAII 32MB
External USB HDD: Seagate FreeAgent 1TB
Network: Home Plugs (NETGEAR Powerline AV Adapter with Ethernet Switch XAVB1004 bridge)
Router: BT HomeHub V2
Display: Panasonic TX-L37G15B
Audio connection: HDMI to TV
Audio output devic
snap
« Reply #4 on: January 28, 2011, 04:46:47 pm »
left-to-right scrolling feels more natural than top-bottom (personal preference) scrolling, mind you.
Either way, navigating using the remote should be easier (so pressing DOWN on the 2nd row should take me to the top row, next column)
deja
« Reply #5 on: January 28, 2011, 08:32:11 pm »
I m c u t y e e d r m e t o i h l n b l n
n y o n r w r a f o l f t r g t i e y i e.
F r h s e s n f n t e u r n s r d s u b n
o t i r a o I i d h c r e t o t i t r i g.
« Last Edit: January 28, 2011, 09:09:11 pm by deja » Logged
