Pages: [1] 2   Go Down
Author Topic: Remove US/UK icon from artwork  (Read 1519 times)
SteveC
« on: January 20, 2011, 12:28:10 pm »
Okay, I give up.
I've run Yamj for Mede8er and it all seems to work fine, video wall is up and running etc.
However, the one annoying thing is that a lot of the films have a US/UK flag in the top left hand corner of the artwork and "SUBS" in the top right. Is there a setting which can be turned off or do I need to source the artwork elsewhere and overwrite?
Don't fancy the second option as there is over 500 films!
Any help appreciated
Steve
Mede8er model: MED500X (*3)
Mede8er model: MED500X2
Network: Devolo 200Mbps Home Plugs
HP EX475 Server (*2)
the-osiris
B8a Tester - 1000X3D
« Reply #1 on: January 20, 2011, 01:36:28 pm »
what skin do you use?
You can edit HTML/CSS file in the skin folder to match your need (enable/disable/remove), but you need knowledge about HTML/CSS.
If you could upload your skin (folder) as RAR/ZIP, maybe I could help to remove it.
You may need to regenerate cover-art with Y2M (no need internet access anymore).
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
SteveC
« Reply #2 on: January 20, 2011, 01:56:18 pm »
Just use the default skin.
« Reply #3 on: January 20, 2011, 02:03:24 pm »
My guess is that there is some param to disable it.
Have not looked for it, but you migh look in the .xml files that are in the default skin folder and search for the correct param.
the-osiris
« Reply #4 on: January 20, 2011, 02:16:54 pm »
is MyLowlist_default_Mede8er or default skin ?
Try to edit skin.properties (in skin folder - skin that you choose) :
Code:
thumbnails.language=false
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
SteveC
« Reply #5 on: January 20, 2011, 04:02:04 pm »
Had already edited skin.properties in the default skin and set thumbnails.language=false. However, on checking i'd put fasle instead of false - IDIOT!
Anyway tried again with a unripped DVD and it works! Only problem now is to redo the other 500+.
Tried to delete jukebox folder (after copying it) and re-run Yamj but it (as suspected) it re-created the wrong artwork etc for some films, which would need to be re-done manually i.e. copy from amazon and edit .xml etc.
Is there a way to speed up Yamj to Mede8er?
I have a folder structure of Videos/ and then each film is in its own sub-folder.
What happens is that I select the DVD folder and run Yamj for that 1 film but it also processes all the other sub-directories for some reason?
Anyway many thanks for your help
Steve
SteveC
« Reply #6 on: January 20, 2011, 04:04:34 pm »
Setting thumbnails.language=false seems to work for removing the country in the top left corner but the "Subs" in the top right remains on most artwork
Any ideas?
the-osiris
« Reply #7 on: January 20, 2011, 04:23:39 pm »
Haven't test DVD structure into YAMJ, but it should work as long as you put your folder structure as :
/Movie_Title_DVD/VIDEO_TS  --> put Movie_Title_DVD folder or above to scan.
For subs, I'm afraid there's no config for removing that. Could you post one jpg sample on which region you wish to remove, I'll try to help by removing it in skin file.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
SteveC
« Reply #8 on: January 20, 2011, 04:31:32 pm »
An example of the file with the "SUBS" displayed in top right hand corner
the-osiris
« Reply #9 on: January 20, 2011, 05:01:59 pm »
try this,
Code:
posters.language=false
but you have to regenerate YAMJ, cause this is poster overlay.
try to generate one title to see it works or not.
btw, you haven't answer my question, is MyLowlist_default_Mede8er or default skin ?
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
SteveC
« Reply #10 on: January 20, 2011, 06:12:25 pm »
Posters.language is already set to false
Unsure where to look for this
the-osiris
« Reply #11 on: January 20, 2011, 06:27:16 pm »
Skin info is on the moviejukebox.properties (in YAMJ folder),
Code:
mjb.skin.dir= Your Skin is Here
Another way to remove SUBS (overlay pic on poster) is to locate PNG file in YAMJ/Skins/Your_Skin/resources folder or in YAMJ/Skins/Your_Skinhtml/pictures, remove it from folder, regenerate YAMJ.
If you could post about.jpg image (whole sheet) for us to see.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
SteveC
« Reply #12 on: January 20, 2011, 08:57:29 pm »
The file called moviejukebox-Mede8er.properties contains : -
mjb.libraryRoot=//SCLTDHPSERVER/Videos/
mjb.detailsDirName=Jukebox
mjb.skin.dir=./skins/default
mjb.playerRootPath=//SCLTDHPSERVER/Videos/
SteveC
« Reply #13 on: January 20, 2011, 08:58:55 pm »
About.jpg attached
SteveC
« Reply #14 on: January 20, 2011, 09:07:16 pm »
As you can tell the About.jpg does not contain the "SUBS" in the top right hand corner only the file black rain_small.png does (stored in the jukebox folder). Hence the Mede8er (V4B5) shows the "SUBS" on the video wall.
Pages: [1] 2   Go Up
