Author Topic: MED200X - MED300X Firmware Update V1.4  (Read 14511 times)
  • Helpful Contribution Status: +101/-24
« on: January 19, 2011, 08:08:50 pm »
MED300X INTERNATIONAL VERSION
RTD1055-16M-HMC-M03P-20110117-v5.0.3.r1535.QA20101117_SDK0804_SANJI_ENGLISH_RC77
http://www.mede8er.org/beta/Firmware_Final/MED300X/MED300X_V1.4_17Jan2011.rar
http://www.mede8er.org/beta/Firmware_Final/MED300X/MED300X_V1.4_17Jan2011.zip
MED300X THAI VERSION
RTD1055-16M-HMC-M03P-20110117-v5.0.3.r1535.QA20101117_SDK0804_SANJI_ENGLISH_RC77(THAI)
http://www.mede8er.org/beta/Firmware_Final/MED300X/MED300X_V1.4_Thai_17Jan2011.rar
http://www.mede8er.org/beta/Firmware_Final/MED300X/MED300X_V1.4_Thai_17Jan2011.zip
MED200X INTERNATIONAL VERSION
RTD1055-16M-HMC-G30P-20110117-v5.0.3.r1535.QA20101117_SDK0804_SANJI_ENGLISH_RC77
http://www.mede8er.org/beta/Firmware_Final/MED200X/MED200X_V1.4_17Jan2011.rar
http://www.mede8er.org/beta/Firmware_Final/MED200X/MED200X_V1.4_17Jan2011.zip
MED200X THAI VERSION
RTD1055-16M-HMC-G30P-20110117-v5.0.3.r1535.QA20101117_SDK0804_SANJI_ENGLISH_RC77(THAI)
http://www.mede8er.org/beta/Firmware_Final/MED200X/MED200X_V1.4_Thai_17Jan2011.rar
http://www.mede8er.org/beta/Firmware_Final/MED200X/MED200X_V1.4_Thai_17Jan2011.zip
Changlog Info V1.4
1. Fixed zoom and crash bug on sqLite database
2. Fixed Next/Previous button jump music player
3. Fixed LPCM Audio bug
Changlog Info V1.3
1. Added "slow" button about.jpg zoom and up/down nav and launch video from about.jpg
2. Added Folder Play function
3. Added support to play BDMV structure files ie Folder Play
4. Linux partitions on HDD hidden from Media Library view
V1.2
1. Changed and added extra "Default" system font
2. Fixed HDD Format problems on on some brands of new unformatted HDD's
V1.1
1. Fixed Audio Downmix problem on HDMI
Update Procedure
Download the latest Mede8er Firmware from www.mede8er.com or www.mede8erforum.com.
UnZIP or UnRAR the file and you will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button and hold it pressed for 10 seconds and then release.
After approximately 15 seconds the LED on the Mede8er with flash red-blue and you will get a progress bar on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 180 sec. You Mede8er is now be updated.
« Last Edit: February 15, 2011, 03:12:13 pm by Mede8er1 »
