Just found out that skin you are using is
old default (in Y2M beta 3)
then you may edit skin.properties (again) :
thumbnails.logoSubTitle=false
this
[SUBS] text is from overlay PNG called
"subtitle.png" under YAMJ\skins\default\resources, those code above will disable them. but again, you have to regenerate YAMJ.
