Pages: 1 ... 7 8 [9]   Go Down
Author Topic: Update on V4 progression  (Read 25056 times)
« Reply #120 on: February 04, 2011, 01:54:38 pm »
Is that via Setup or Tv Sys button?
sjweemie
« Reply #121 on: February 04, 2011, 03:23:31 pm »
Via setup.
shizzl
B8a Tester - 1000X3D
« Reply #122 on: February 04, 2011, 05:16:10 pm »
2. videowall as default after mede8er startup or at least make the default selectable
great job
keep an eye on modding section...
MED1000X3D
alexander
« Reply #123 on: February 05, 2011, 07:37:26 pm »
hmm samsung has some problems with firmware Smiley dont know if it is related to your problem !
Now another thing i noticed !
Today i'm the proud owner of a 2 terabyte wd green hard drive !
Installed it (peace of cake )
format it , and then i made three dirs on them ! Films (movies ) foto's (photo ) and Muziek (music ) !
After that i copied from the network a dir with a movie... by accident i put it in the root of my internal hard drive instead of the Films directory !
Okay no problem.  selected the dir , select the option Move (verplaatsen ) instead of kopieeren (copy ) after all it just needed to be moved inside the dir films..
I then got a blue bar and nothing happened... no progress was to see on the screen !
When i select copy i see a bar with floating papers from left to the rigt !  so i did see a progress
Now the question is this a fault or a bug ?
Administr8or
Online Online
« Reply #124 on: February 05, 2011, 08:31:58 pm »
Hi alexander
It is a bug
alexander
« Reply #125 on: February 06, 2011, 12:38:38 pm »
hmm nice , so what do i need to feed this bug or do i just need anti bug spray  Grin
Okay,  guess it will be solved in the near future Smiley
by the way a little side note from my site !
copy files from the nas in  my network (on the firts floor ) to my HDD of my mede8er went proberly fast (as i heard that it was slow ) but maybe it come's that i have a gigabyte network (and yes i know the mede8er has only 100 ... ) with cat 6 cables and giga switches !
« Reply #126 on: February 06, 2011, 12:55:24 pm »
Slow or fast is down to the user. Many can't achieve the spec figure of 4.4 mb/s, and consider their system to be slow, that is slower than spec. If you have a high spec NAS, achiving the spec figure of 4.4 mb/s is pitifully slow compared to transferring to a PC.
wrestlemagic
« Reply #127 on: February 16, 2011, 03:05:10 pm »
It still throws up subtitles. Constantly need to turn them off. Cry Huh
Best wishes
Wrestlemagic
« Reply #128 on: February 16, 2011, 09:08:45 pm »
Best wishes
Wrestlemagic
Issue regarding subtitles on on DVD movies is known issue and needs to be fixed.
Pages: 1 ... 7 8 [9]   Go Up
