« on: January 10, 2011, 06:07:04 pm » |
All,
Some update on the V4 progression:
Mede8er devs are making good progress and all SDK bugs have been adressed one by one and now we are in a good position to move forward on the last internal debug stage. We will not give a timeline but it is weeks and not months.
regards, Maasbommel
« Reply #1 on: January 10, 2011, 06:18:18 pm » |
SDK Bugs? Sounds like Sanji are having to spend as much time fixing realteks code as their own!
bluntspoon
B8a Tester - X2
Offline
...no one really knows...
« Reply #2 on: January 10, 2011, 09:46:00 pm » |
That's great news. Good start to the new year...
Home Theater Setup: Samsung LA40C650L1R Mede8er MED500X2 Mede8er MED400X
Domino1999
Senior Member
Offline
« Reply #3 on: January 10, 2011, 09:50:23 pm » |
This is old news. They reported in October that the latest SDK had bugs and Realtek had to fix them. Nevertheless, it's good news that a final V4 should be with us in a few weeks (and if not months then I can only presume it will be within the next month) ;-)
Mede8er model: MED500X Board: 1073DD Bootloader: 0000.0202.1026 Firmware: V4.04 INC_HD Audio Internal HDD: WD20EADS 3.5" Caviar Green 2TB SATAII 32MB External USB HDD: Seagate FreeAgent 1TB Network: Home Plugs (NETGEAR Powerline AV Adapter with Ethernet Switch XAVB1004 bridge) Router: BT HomeHub V2 Display: Panasonic TX-L37G15B Audio connection: HDMI to TV Audio output devic
markt1891
« Reply #4 on: January 10, 2011, 10:07:03 pm » |
mmmm..... I think 7 weeks could be less than "months" (8 weeks)
MED500X f/w v4.04 / MED400X2 f/w v2.0.1 / Denon AVR-F100 / 1gb Cat5e / Netgear GS716T-200 / Windows Home Server PP3 2 x 2tb / Panasonic TX-L37V10
maboane
Offline
« Reply #5 on: January 11, 2011, 08:41:23 am » |
I can't wait for my Video Wall again. Good work guys keep it coming.
Mark1981
Offline
« Reply #6 on: January 11, 2011, 10:46:16 am » |
 Good news. I am happy with v3.05, but the only drawback is that it has no support for MKV header compression. V4 has support for header compression so that is a major improvement, also the new GUI ( videowall 3 levels deep ). Hope that the new SDK from Realtek has fixed the bugs with almost all problems with the audio. If that is the case i am a happy camper
Mede8er model: MED500X Board: 1073DD Bootloader: 0000.0202.1026 Firmware: V4.04 No HD Audio Internal HDD: none External USB HDD: Iomega 500 Gb Display: Samsung LE37CE530 Audio connection: HDMI to TV
homertje
Offline
Changing the world, one byte at a time.
« Reply #7 on: January 11, 2011, 05:04:41 pm » |
If the unofficial and kind of unreleased v4beta6 is nearly the same as the final version of v4 then i have to admit, NICE work!
Mede8er model: primary: MED400X Mini. (secondary: MED500X) Network: Mede8er <- (100Mb/s cat5e) ->HP ProCurve 1810G<- (2Gb/s cat6 LACP) ->Debian 6 Linux server. Audio output: via HDMI to Yamaha RX-V663 AV receiver. Display device: Yamaha RX-V663 HDMI out to HD Beamer: Acer H7530D.
the-osiris
« Reply #8 on: January 11, 2011, 05:25:57 pm » |
good news indeed
« Reply #9 on: January 11, 2011, 05:45:59 pm » |
Which makes the news even worse! It sounds like realtek can't accept this SDK release is a lemon and needs a close look at. Instead the tone of Massbommels post is that OEM's like Sanji have to prove there is a bug before realtek will fix it, one by one!
norzain
Offline
« Reply #10 on: January 12, 2011, 08:03:44 am » |
That's what 'Mede8er devs' a for!!!
bluntspoon
B8a Tester - X2
Offline
« Reply #11 on: January 12, 2011, 08:22:35 am » |
This is often the case with the software industry...
leuk_he
Offline
« Reply #12 on: January 12, 2011, 06:31:26 pm » |
If there only was some advancement in the NTFS driver bug... In This post There is a easy to reproduce test case. I has someone test this on the xtreamer pro and it had the same problem, so it definitly is a SDK bug from the ntfs driver supplier . And data corruption should be VERY high on the list of any developer. A hang is easy to recover form (power of/power onn), but data corruption might cause you to do a hour taking complete resinstall (if there is a backup). Any device calling itself (barely) a NAS should be able to safe files without dataq corruption. @ maasbommel, why not add it to the beta 4 bug list? (or call it "support native ext3 partition" since that is a good workarround)
mobetterblues
Offline
« Reply #13 on: January 12, 2011, 07:25:48 pm » |
Can anyone advise if the Drive letter issue on the videowall has been sorted for the soon to be new beta?
nagubal
Offline
« Reply #14 on: January 14, 2011, 01:35:57 pm » |
If there only was some advancement in the NTFS driver bug... In This post There is a easy to reproduce test case. I has someone test this on the xtreamer pro and it had the same problem, so it definitly is a SDK bug from the ntfs driver supplier . And data corruption should be VERY high on the list of any developer. A hang is easy to recover form (power of/power onn), but data corruption might cause you to do a hour taking complete resinstall (if there is a backup). Any device calling itself (barely) a NAS should be able to safe files without dataq corruption. @ maasbommel, why not add it to the beta 4 bug list? (or call it "support native ext3 partition" since that is a good workarround) I am very pleased with my med500x (I bought it a year ago), BUT the NFTS corruption problem with I encounter very often, is the only real issue which makes me want to sell the med500x and go the Dune way (Smart series, H1 or D1)...
