Pages: [1] 2   Go Down
Author Topic: passthrough spdif problems  (Read 1841 times)
maddness1001
« on: January 07, 2011, 08:02:32 pm »
i have a problem with some video files.
when i choose passthrough spdif some movies gives sound but some movies doesn't.
but when i choose spdif downmix sound always works.
i have a  panasonic sc-pt470g-k home cinema system.
http://www.bobshop.nl/nl/beeld-en-geluid/home-cinema-sets/panasonic/sc-pt480eg-k-home-cinema-systeem/p33559
« Reply #1 on: January 07, 2011, 08:20:09 pm »
Please look at the Technical Support Guidelines, need some more details about used firmware etc.
http://www.mede8erforum.com/index.php/topic,14.0.html
Without these details its not possible to get any clue what the root cause is of this and not possible to give any solution.
stalensnuitje
« Reply #2 on: January 07, 2011, 09:50:35 pm »
I 've had the same thing, no sound on *.MP4 movie files, on both V3.05 and V4 BETA5.
I'm converting the file to WMV now to see what that does.
Oh by the way: after reinstalling firmware things seemed to work again.
Product & firmware version: Mede8er MED500X f/w v3.05 / v4 BETA5
Audio: Optical output > Philips LX-7100 home theater system
Video: Composite > Old Philips TV
Video setting: 1080p 50Hz,24Hz OFF,4:3 Letterbox
Media Source: Internal HDD
Hard Drive: Samsung HD103SJ 1TB, formatted using Mede8er setup
« Last Edit: January 07, 2011, 09:56:26 pm by stalensnuitje » Logged
stalensnuitje
« Reply #3 on: January 07, 2011, 10:27:08 pm »
Ah well, just tried, reinstalling firmware didn't work, neither did changing to Downmix (2ch).
So basically, I downloaded a file in both MP4 (h.264) and WMV (invalid video file Huh) and still no sound whatsoever. This is making me quite angry to be honest, I bought the Mede8er to get rid of all the SH*T of converting etc. before being able to watch a movie. Now I spent a handful of money and I'm still tweaking and fiddling my ass of  Angry
maddness1001
« Reply #4 on: January 07, 2011, 10:54:33 pm »
Product & firmware version: Mede8er MED500X f/w 3.0.5 latest dec 2010
Audio: Optical output > panasonic sc-pt470g-k
Video setting: 1080i 50Hz,24Hz off ,16:9
Media Source: Wired Network > Windows 7 shares
« Reply #5 on: January 07, 2011, 11:13:42 pm »
Suggest to post some media info output of one of the trouble giving files http://mediainfo.sourceforge.net and/or post a sample on mede8er ftp site http://www.mede8erforum.com/index.php/topic,279.0.html so others can give it a try.
stalensnuitje
« Reply #6 on: January 07, 2011, 11:22:58 pm »
Hey thanks, I'll give it a try later this weekend.
Great feedback and a lot of answers/help on the forum, that's really worth a lot  Smiley
« Reply #7 on: January 07, 2011, 11:31:48 pm »
Maddness,
Can you also post some media info with the tool I pointed to from one of the files that don't give sound on passthrough spdif?
stalensnuitje
« Reply #8 on: January 08, 2011, 10:16:41 pm »
Maasbommel, do you know a tool to just cut a video file into a piece of <100mb, without the need to (re-)encode it?
maddness1001
« Reply #9 on: January 09, 2011, 12:03:29 am »
formaat                          : Matroska
Bestandsgrootte                  : 13,1 GiB
Duur                             : 2h 58mn
Totale bitrate                   : 10,5 Mbps
Datum codering                   : UTC 2010-03-21 18:34:15
Gebruikt programma               : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Gebruikte encoderbibliotheek     : libebml v0.7.9 + libmatroska v0.8.1
Video
Formaat                          : AVC
Formaat/Info                     : Advanced Video Codec
Formaatprofiel                   : High@L4.0
Formaatinstellingen, CABAC       : Ja
Formaatinstellingen, ReFrames    : 5 frames
Format_Settings_GOP              : M=4, N=14
Codec-ID                         : V_MPEG4/ISO/AVC
Duur                             : 2h 58mn
Bitrate                          : 9 019 Kbps
Breedte                          : 1 920 pixels
Hoogte                           : 800 pixels
Beeldverhouding                  : 2,40:1
Framerate                        : 23,976 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
Scansoort                        : Progressief
Bits/(Pixel*Frame)               : 0.245
Stroomgrootte                    : 11,0 GiB (84%)
Gebruikte encoderbibliotheek     : x264 core 89 r1471M 1144615
Instellingen codering            : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9019 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0
Taal                             : Engels
Audio
Formaat                          : DTS
Formaat/Info                     : Digital Theater Systems
Formaatprofiel                   : ES
Codec-ID                         : A_DTS
Duur                             : 2h 58mn
Bitrate-modus                    : Constant
Bitrate                          : 1 510 Kbps
Kanaal(en)                       : 6 kanalen
Kanaalposities                   : Front: L C R, Side: L R, LFE
Samplerate                       : 48,0 KHz
BitDepth/String                  : 24 bits
Stroomgrootte                    : 1,88 GiB (14%)
Taal                             : Engels
maddness1001
« Reply #10 on: January 09, 2011, 12:05:51 am »
here is a second one that doesn't work
Algemeen
UniqueID/String                  : 246003006872720147599159120936274389957 (0xB91274AB04EF54258D51406813D26BC5)
Volledige naam                   : D:\Film High Definition\Adventure\Clash Of The Titans 1080p\Clash Of The Titans 1080p.mkv
Formaat                          : Matroska
Bestandsgrootte                  : 7,95 GiB
Duur                             : 1h 46mn
Totale bitrate                   : 10,7 Mbps
Datum codering                   : UTC 2008-07-03 03:40:58
Gebruikt programma               : mkvmerge v2.9.8 ('C'est le bon') built on Aug 21 2009 13:21:42
Gebruikte encoderbibliotheek     : libebml v0.7.7 + libmatroska v0.8.1
Video
Formaat                          : AVC
Duur                             : 1h 46mn
Bitrate                          : 9 209 Kbps
Hoogte                           : 800 pixels
ColorSpace                       : YUV
Bits/(Pixel*Frame)               : 0.250
Stroomgrootte                    : 6,67 GiB (84%)
Gebruikte encoderbibliotheek     : x264 core 100 r1659 57b2e56
Instellingen codering            : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9209 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Taal                             : Engels
Audio
Formaat                          : DTS
Codec-ID                         : A_DTS
Duur                             : 1h 46mn
Stroomgrootte                    : 1,12 GiB (14%)
Taal                             : Engels
maddness1001
« Reply #11 on: January 09, 2011, 12:06:36 am »
this one does work
UniqueID/String                  : 240740648395094240959182105689124598165 (0xB51CF65D102B1CF1B6D5EABEAB757195)
Volledige naam                   : D:\Film High Definition\Science-Fiction\Star Trek 11 - The Future Begins 1080p\Star Trek 11 - The Future Begins 1080p.mkv
Formaat                          : Matroska
Bestandsgrootte                  : 8,75 GiB
Duur                             : 2h 6mn
Totale bitrate                   : 9 873 Kbps
Datum codering                   : UTC 2009-10-01 13:50:25
Gebruikt programma               : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Video
Formaat                          : AVC
Formaatprofiel                   : High@L4.1
Duur                             : 2h 6mn
Bitrate                          : 9 232 Kbps
Hoogte                           : 800 pixels
ColorSpace                       : YUV
Bits/(Pixel*Frame)               : 0.251
Stroomgrootte                    : 8,01 GiB (92%)
Gebruikte encoderbibliotheek     : x264 core 76 r1271 496d79d
Instellingen codering            : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9232 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Taal                             : Engels
Audio
Formaat                          : AC-3
Formaat/Info                     : Audio Coding 3
Format_Settings_ModeExtension    : CM (complete main)
Codec-ID                         : A_AC3
Duur                             : 2h 6mn
Bitrate                          : 640 Kbps
BitDepth/String                  : 16 bits
Stroomgrootte                    : 581 MiB (6%)
« Reply #12 on: January 09, 2011, 02:16:34 am »
http://lmgtfy.com/?q=cut+video+without+re
« Reply #13 on: January 09, 2011, 02:22:42 am »
Hi Maddness,
It looks like movies with DTS sound give the trouble on SPDIF if I look at your Media Info output.
The other one has AC-3
Did you have the same experience on 3.0.4 version firmware?
maddness1001
« Reply #14 on: January 09, 2011, 01:05:12 pm »
i am testing now with my ps3 with a bluray movie but no dts either, i going to do a few more tests
Pages: [1] 2   Go Up
