Author Topic: [Tip] Network Med500 with PC or NAS more reliably.  (Read 36178 times)
« on: January 02, 2011, 04:53:16 pm »
This Tip was developed during the use of V3 firmware. Those who have similer problems with V4 are advised to re-install the firmware again and re-test Networking before implementing this Tip.  WINS/DNS are the most common cuases of Networking Problems.  There is a list of rare causes that have affected individual users and those can be found nearer the bottom of this Tip.
The Med500 NAS keeps appearing and disappearing as we know. But disappearing  from what?
http://support.microsoft.com/kb/172218
So we have two issues, WINS Management problems causing the Med to not appear in the Network Discovery Display, and DNS Management problems causing failed connections with the Med. The WINS problem can also affect connections from Med to PC.  The infamous User/Password request  should vanish once  this Tip is used to fix WINS at the PC end.
Networks can suffer either, or both, of these problems, but it's  best to try and fix WINS first, and then add the DNS fix if the WINS fix fails.
The DNS Fix may have problems where the Router dosn't have a Proxy (Caching) DNS Server in the router to help Local DNS resolution. You have one if you get the routers IP in the DNS Server field when using "Get DNS Server Automatically" in your PC's adapter IPV4 settings. If you get your ISP's DNS Server IP, you don't have a Router DNS Proxy enabled. These may not be explicity described as a DNS Proxy.   You may a DHCP Client page which will link Mac Number, Name and IP together. An alternative solution can be tried if you don't have a Proxy DNS Server in your router, and is described later.
Windows performs Network Discovery by requesting devices to send their Names, not IP's. Not all routers can pass this request,  expecting instead for Network Discovery to request IP's from devices. DNS is then used to identify the IP. So it's possible for WINS to find the Med using Names, and then DNS to fail when you try and connect to it's IP. With Windows you get this error message when  that happens:-
Error Code:0x80070035
The network path was not found.
To solve this we must avoid contention with the automatic systems which should be doing the job.  Files are used by Microsoft for that very purpose. If Networking was  totally reliable those files would never have been created. They have been in use since the  start of TCP/IP and Unix. You will find the same files are part of the TCP/IP system of other operating systems.  They exist to workaround the very problems we are having with the Med500 and some Networks.
Some have found that once they have a working network as a result of this Tip, the changes can be removed and their network still works. It's as if other components of the WINS/DNS system  have been made aware of the Med and can now work without the help of the host files. These components, such as remote DNS servers, may lose that awareness at some point. The Fix will then have to be re-applied.
These instruction are based on Windows 7.
1) Set Manual IP settings in the med500, and PC so that they both have LAN addresses (outside of the DHCP pool).  You may have to set the DNS server and Default Gateway values, which for a Router with Proxy DNS Server are the IP of the Modem/Router.
We now need to get the Med500  to always  be part of the DNS and Network Discovery information.
2) Update the  Network Discovery WINS Lmhosts file.
Open and save the document attached below to your default download folder. This is a new Lmhosts file. Edit the downloaded lmhosts.doc document to match the address you gave your Med500,  and save as lmhosts.txt (not .doc!!!). This will be used later so remember where it is.
Open Network and Sharing Center. Select Change adapter settings. Double click on the adpter you are using. Select Properties . Select IPV4 - Properties. Select Advanced - WINS. Select  Enable LMhosts Lookup, and press Import LMHOSTS and browse to select lmhosts.txt where you saved it.  Also select "Netbios over TCP/IP" if you havn't yet followed the advice in the "Beginners Guide".
Press all the OK's and final Close to exit Adapter Settings. Reboot
Test Workgroup connections from the MED, and NAS connections from the PC. If they fail,  move on to the DNS fix, otherwise Goto 5).
3) Modify the default DNS Hosts file (for those with a Router Proxy Server).
Goto Accessories and open Notepad with Administrator Priveledges
Open \Windows\System32\drivers\etc\hosts from within Notepad.
Copy, and paste the line below to the end of the file.
192.168.2.202    MEDE8ER
Edit to match the IP you gave your Med, and make sure there is a final Carriage Return by pressing Enter after MEDE8ER to create a new blank line.
Save file (ignoring any request to change format to TXT).
Reboot. Test Workgroup connections from the MED, and NAS connections from the PC.
Goto 5
4) Install DNS Proxy Server and modify it's DNS Hosts file (for those without a Router Proxy Server).
Download and install Acrylic DNS Proxy Server on to PC
http://mayakron.altervista.org/support/browse.php?path=Acrylic&name=Home
Use the Start Menu to run the Modify Acrylic Configuration File shortcut.
Follow instruction in file to modify fields. This makes Acrylic aware of the "real"  DNS servers.
Use the Start Menu to run the Modify Acylic Host Files shortcut
Use the Start Menu to run the Start Acrylic DNS Proxy Server shortcut.  The server starts, and will start every time the PC boots.
You should also set up your adapter to use 127.0.0.1 as the DNS Server IP.
The Med should continue to use the "real" DNS server.
Many needing to use Acrylic find that once their network is working they can remove it and change their settings back to use the "real" DNS servers.  It's as if Acrylic has forced those servers to recognise the Med when they didn't before.
Those using OSX could try this:-
http://web.me.com/brianwells/main/pdnsd.html
5) Post Fix
The Med500 should now be more reliable in both TCP and Network Discovery on the PC.
To check the Med is now in both caches perform the following:-
LMHOSTS/WINS - Run nbtstat -c at the  command  prompt.
HOSTS/DNS - Run ipconfig /flushdns, followed by,  ipconfig /displaydns at the command prompt.
Reliabilty of Network Discovery still seems dependent upon which order the Med500 is turned on WRT the router and PC. Windows 7 has a particuler dislike to non-Windows 7 devices. It can take 15 mins for it acknowledge their presence!
But the DNS fix still works when that fails. So it worth having a Shortcut to \\MEDE8ER on your Desktop. This opens a Network Explorer Window, similer to the normal Windows Explorer Window. It even gets the Med added to the list of Network Devices!
In general, becuase the PC has the Med fixed in it's IP Cache by the fix's above, the Med connects to the PC far more reliably as well!
Rare Problems
Even after following the above, you may still across some rare problems
1) Networked Folders are visible but can't be opended
Follow this Tip
http://www.mede8erforum.com/index.php/topic,4427.0.html
2) Believe it or not, but your Network may not be working becuase your clocks are out of step!
http://social.technet.microsoft.com/Forums/en-US/w7itpronetworking/thread/68ffbe2a-09a7-4e29-859c-ca1aaf75dcd1
Make sure your Med's internet clock is working and in synch with your PC. It everything has stopped working since the end of Summer time, you now know why.
3) Overnight loss of Window 7 sharing
http://www.patriotmemory.com/forums/showthread.php?4095-Windows-7-Lost-Shares-and-Microsoft-6to4-Adapters
This can be cleaned up  as described here:-
http://www.ryanvictory.com/posts/automating-6to4-adapter-removal-in-windows/
There is a hotfix which might prevent it happenning again:-
http://support.microsoft.com/kb/980486
Addendum
Here are the locations of these files in other Operating Systems. It is probably safer to edit these and not replace the Lmhosts with my windows file.
Ubuntu users can find their versions here:-
http://manpages.ubuntu.com/manpages/hardy/man5/hosts.5.html
http://manpages.ubuntu.com/manpages/hardy/man5/lmhosts.5.html
OSX users can find their versions here:-
http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/man5/hosts.5.html
http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/man5/lmhosts.5.html
« Last Edit: June 28, 2011, 11:47:50 am by jer1956 »
Offline diapason
Re: [Tip] Network Med500 and PC more reliably.
« Reply #1 on: January 19, 2011, 06:45:43 am »
Hi All,
Would these problems still exist or how would things change, if the pcs and the M500x were to be connected to a seperate ethernet hub and then the hub to the router?
Diapason
Diapason
1 * Mede8er 1000X3D, FW 301
2 * Mede8er 500x2,FW 210,
1 * 500x, Fw 405,
Lan to pc network 1 *xp, 1 * Win 7.
HDMI to Cambridge Audio Azur 651R
Hdmi to Samsung PS50C550
Cambridge Azur 650BD Player
« Reply #2 on: January 19, 2011, 11:36:19 am »
If you already have the problem I doubt it would solve it. What do you mean by a HUB? An additional lan switch , a lan bridge?
No one on the forum has a definitive idea what's behind this. If we did we would be advising that you check for X or Y in your router before buying etc.
Offline chicken-
« Reply #3 on: February 01, 2011, 07:20:27 am »
Thanks for this thread, I'm not sure if this fixed it or the V4 firmware but either way it's the first time in over a year owning this damn thing that I've been able to get this thing to join the network after cable unplugs or router resets.  I've always had to toggle the NAS mode off and on 2 times to get it to join the network, never had it leave the network once it's on until something resets but that was really annoying.  My internet is terrible and goes down a lot and i have a dsl modem/router combo so I'm constantly rebooting the thing and having to mess with the mede8er.
Re: [Tip] Network Med500 with PC or NAS more reliably.
« Reply #4 on: March 08, 2011, 10:39:41 am »
Bump:-
Tip has been modified to add a DNS Proxy Server alternative to editing the hosts file. This may help those who don't have a DNS Proxy Server in their router.
« Last Edit: March 09, 2011, 01:12:29 pm by jer1956 »
« Reply #5 on: March 10, 2011, 09:56:55 am »
Bump:-
V4 is more reliable than V3. Those who do have problems may not have to fix both WINS and DNS. The Tip has been restructured to match that. I no longer need the DNS fix. Indeed Karkal, who kindly tested the Acrylic Fix, has found the Fix can be removed completely once the Network is working. It's as if other parts of the DNS system are able to function as they should once they are aware of the MED.
« Last Edit: March 11, 2011, 09:40:20 am by jer1956 »
« Reply #6 on: March 13, 2011, 12:21:10 pm »
Bump:
Many users with V4 Networking issues are reporting re-installing the firmware is enough to fix it. The Tip has been modified to reflect this. Hopefully this tip will become redundant for the vast majority of those with networking problems.
Offline StNick
« Reply #7 on: March 21, 2011, 06:25:21 am »
I copy content to my Mede8er across my wireless network (D-Link DAP-1360) via Windows (using the NAS feature).  Since wireless is slow (I get about 2.7MB/sec), I often have to set it to copy over night whilst I sleep.
Lately I have noticed that my tranfers are bombing out with the message "the network resource no longer exists".  I tried all the tips and tricks in this thread to no avail, but I'm happy to report that I have one more "tip" to add here.
For me, setting the wireless preamble in the router to "short" corrected the problem.  I can now copy for hours on end without any transfer interruptions.
I hope this helps others experiencing similar issues.
Offline qzplx
« Reply #8 on: June 15, 2011, 01:48:55 am »
Luckly!
I just want to post my question, I've just bought wireles dongle for mede8er, at the first time, I was able to copy my whole movie which is around 40gb overnight, and suddenly the second day I've got interruption which is i believe its a same error.
But, im using belkin wifi G access point, anyone know which of the setting should I change ?
Offline qzplx
« Reply #9 on: June 20, 2011, 02:08:26 am »
My Solution is make your own etc/hosts and assign the mede8er as static IP.
Now my network flawless
« Reply #10 on: June 20, 2011, 09:08:56 am »
Great, you worked it out indepedently. It's good to have users who can workaround problems for themselves. They can  then post a [TIP], like I did, to help others. As you can see your solution already has a [Tip].
« Reply #11 on: July 10, 2011, 09:57:43 am »
A link describing very well the steps to troubleshoot and solve connecting to shares:
http://www.petenetlive.com/KB/Article/0000439.htm
And be sure to have NETBIOS over TCP/IP is enabled on the properties settings of your PC lan card under Wins tab.
« Last Edit: July 10, 2011, 10:04:03 am by Maasbommel »
