Author Topic: playing podcasts  (Read 308 times)
Superwuppy
« on: January 02, 2011, 01:28:57 am »
hi
can they make it possible
for the med500X to play podcasts Huh
got a lot but cant play them on Med500X
have to convert to mp3
it's a shame some podcasts have images within the music
pimthunder
« Reply #1 on: January 03, 2011, 07:08:18 pm »
Wouldn't it work if you copy the podcast from itunes for example, and then paste it as a m4a file on your hard drive? I haven't tried it myself, but it worked for the songs i bought from itunes.
Superwuppy
« Reply #2 on: January 03, 2011, 08:36:27 pm »
done that
get 2 files
1 normal
and 1 with _ infront
but when i try to play one of both mede8er wouldn't play them.
« Reply #3 on: January 03, 2011, 09:11:33 pm »
They might have some pedia protection it or its some unsupported codec.
Post some media info output from those files to get more input.
