Author Topic: V3.05 Internet Radio Issues  (Read 966 times)
febstar
« on: January 02, 2011, 02:14:46 pm »
Hi All,
I have a MED500X
Spdif pass,
2 TB Innternal,
Ik get an error with the Internet stations.
Doesn´t load any radio stations. I got a good working Internet
Regards
Febstar
« Reply #1 on: January 02, 2011, 02:25:55 pm »
See: http://www.mede8erforum.com/index.php/topic,3865.msg26275.html
You need to upgrade to firmware version 3.0.5 or might consider to load the V4beta5.
Read carefully the upgrade instructions is your are going to upgrade.
Gighen
« Reply #2 on: January 02, 2011, 03:25:02 pm »
Same problem here as I wrote yesterday in the other topic,tried to reinstall 3.0.5 with no results.
I will wait for next update I think...
febstar
« Reply #3 on: January 03, 2011, 11:30:31 am »
Hi Maasbommel,
Sorry i was not compleet with my information.
I use a D-Link D-65
I have installed the Beta V5beta5, and now i installed 3.05 with no result.
It won't download any stations, i get the message that there is " Download failed"
febstar
« Reply #4 on: January 03, 2011, 12:08:08 pm »
Hi Maasbommel,
I use a D-Link D-65
febstar
Are you using DHCP setting on your Mede8er?
Did you try to power off and power on your router to reset your network?
Did you use configrestore option ? Or not. Prefered to not use this.
What error message do you get?
« Reply #5 on: January 03, 2011, 12:38:48 pm »
Hi Maasbommel,
I use a D-Link D-65
febstar
Download failure dosn't happen as a result of the shoutcast changes. Your not getting onto the internet through your router.
febstar
« Reply #6 on: January 04, 2011, 08:46:11 pm »
Thanks,
But My laptop and Ps3 have no problems at all.
So i am missing the link here.
Regards, En bedankt Maasbommel !
Febstar
« Reply #7 on: January 04, 2011, 09:06:31 pm »
Try updating the internet time in the med using setup. That should test that the med is connecting to the internet.
febstar
« Reply #8 on: January 04, 2011, 11:13:56 pm »
Hi jer1956 ,
That works fine. It sync's the internet time without a problem.
Any other ideas ?
Regards
Febstar
« Reply #9 on: January 05, 2011, 01:07:16 am »
Did you already look at this:
Did you use configrestore option ? Or not. Prefered to not use this as you might copy wrong shoutcast ip from an earlier config.
« Reply #10 on: January 05, 2011, 11:38:15 am »
Check your router to see if it has a secutiy page with selectors for Denial of Service, or Flood Detection. Some routers have very sensitive filters for these, and they over react to the large number of small files which shoutcast sends out to a small request. If you don't have such a page, you may have to test that it's a firewall problem by turning the router firewall off. Your PC should be safe behinds it's own firewall. If you've turned it off, turn it back on for the test.
« Last Edit: January 05, 2011, 11:42:57 am by jer1956 » Logged
febstar
« Reply #11 on: January 06, 2011, 09:42:52 am »
Hi Maasbommel,
I already did that all.
jer1956, i will check that and come back to you asap.
Regards,
Febstar
Sturbo
« Reply #12 on: January 29, 2011, 11:37:19 pm »
Hi Febstar,
I had the same problem for quite a while, but I just solved it.
In the settings menu --> network tab --> LAN settings --> DHCP, there's an IP-adress for the DNS-server. That appeared to be incorrect in my case. I found a correct DNS-IP in my routers settings. As soon as I filled in the right DNS-server IP-adress, my Internet radio worked fine again.
Good luck!
« Reply #13 on: January 30, 2011, 01:20:01 pm »
What make/model of router was that? Routers should send out the correct IP address for the DNS server to devices using DHCP.
