Author Topic: DuneX now works with mede8er  (Read 27979 times)
Offline mognons
  • printf("Hello, world! \n");
Re: DuneX now works with mede8er
« Reply #15 on: July 03, 2012, 08:46:50 AM »
If there enough request of such a program I may try and write down some code for OSX...
And here it is  ;D
Proud user of DuneX2Mede8er
Offline prod75
« Reply #16 on: January 15, 2013, 12:25:18 AM »
Hi.
I've just installed duneX on my Mac and did a first run analysis.
Movies were detected but picture and movie scrap is not downloaded.
I can see that the movie was detected because if I navigate down the list I can see the year being updated and being the correct year for the selected movie.
Even if I do a manual search the movie synopsis doesn't show.
Am I doing something wrong?
Thanks.
Pedro
Offline mognons
« Reply #17 on: January 15, 2013, 07:43:48 AM »
Hi Pedro,
You should check DuneX settings regarding info source and language settings. There's a chance that data is not fully available for your own language or that the selected movie source API are broken: TMDB API have changed over time, for instance...
Offline prod75
« Reply #18 on: January 15, 2013, 12:06:35 PM »
Hi mognons. Thanks for the reply.
Yesterday I tried The MovieDB and IMDB also (only 3 option, the 3rd one was french if  I'm not mistaken).
Both did not retrieve all information, although to be fair IMDB did give me director and actors information. Neither gave me synopsis.
Language was set to English and I did not change that from default.
Could it be an API problem? With both TMDB and IMDB?
Thanks for the help.
Pedro
Offline mognons
« Reply #19 on: January 15, 2013, 12:49:17 PM »
Hi Pedro, it could be a problem with the source: IMDB changes often their interface and DuneX, AFAIK. relies on an external plugin to access IMDB. TMDB transitioned from API v2 to v3: it may be that your version of DuneX supports only v2 APIs. Try to update it or get in touch with its developer to have any news about it.
