ZwarteMagica
Offline
« Reply #30 on: December 23, 2010, 02:24:55 am » |
Rechecked all settings, but with no result. Port setting: 8000-8005. UpnP on.
ADSL2+ / Zyxell P-2602HW / Sony Bravia (HDMI & Network) / Sony S550 / MED500X - Firmware V4Beta5 / All network wired
« Reply #31 on: December 23, 2010, 10:28:21 am » |
Try to setup Virtual server in your router and point that to the ip of your Mede8er.
bluebird
Offline
« Reply #32 on: December 23, 2010, 11:04:32 am » |
Hello @all. I´ve the same problem. Downloading the stations does not work anymore. It has been working but now without any change it doesn´t. But I can listen to stations that are in my favourites. I´ve done some analysis: Nslookup from my pc: C:\>nslookup www.shoutcast.comNicht autorisierende Antwort: Name: www.gwww.shoutcast.comAddress: 64.12.96.234 Aliases: www.shoutcast.comProbably there is a round robin A record in the DNS. Second query delivers this: Nicht autorisierende Antwort: Name: www.gwww.shoutcast.comAddress: 205.188.27.1 Aliases: www.shoutcast.comBoth servers are not reachable via ping. (Not from my PC and not from mede8er) Moreover I cannot connect to these server using "telnet <SERVER IP> 8000". But the web page www.shoutcast.com is reachable with my web browser and I can listen to radio stations. (I do not have a active connection in parallel to www. shoutcast.com) I do not have any active firewall and I activated the UPNP feature. Furthermore I made a restart of my router, switch and mede8er. I do not have any other connection problems with the med. Pls Help
med500, V.3.0.4, Internal HDD, UE40C6710
ZwarteMagica
Offline
« Reply #33 on: December 23, 2010, 11:13:45 am » |
I set my Router port according to this guide. But this gave no solution. Is there a possibility to check the internal link in the linux kernel to what addres the ShoutCast application tries to connect?
« Reply #34 on: December 23, 2010, 12:38:32 pm » |
Guys,
Please also post what Firmware release you are using to set the right base to compare things. Give input about your network settings, how things are connected, how your network equipment is connected to each other to the Mede8er, Brand/type or router etc.
See the Tech Support Guidelines howto give enough details.
regards, Maasbommel
« Reply #35 on: December 23, 2010, 01:13:56 pm » |
I just tried Shoutcast (using 3.0.4) after not using it for a couple of months and... it's not working! I get Download Success and then Service Unavailable if I do anything further.
According to shoutcast users the service has been patchy since changes to shoutcast 2 in July. That's when the Genre list was updated as well.
P.S Port Forwarding won't solve shoutcast reception problems. You only need open shoutcast ports if your running a shoutcast server.
« Last Edit: December 23, 2010, 06:51:00 pm by jer1956 »
bluebird
Offline
« Reply #36 on: December 23, 2010, 02:08:13 pm » |
here are some details of my config:
Mede8er500X (old chipset) Firmware: V3.0.4 BootLoader: 0202.0017L
Networkconfig:
All devices (pc, TV, mede8er,etc) are connected to a L2 switch (LevelOne FSW-1621 Fastethernet). The mede8er is using DHCP to get the ip-config. This switch is connected to a router (dsl easybox 802 Firmware Version:20.02.220)
I´m using firefox as the standard browser.
A few more details (might be helpful):
I noticed this problem on my mede8er one week ago. After that I tried to reach the shoutcast page with my browser. At that moment I got the error message "Service temporary not available" within my browser. But now the page is working again and the mede8er still has got the problem.
« Reply #37 on: December 23, 2010, 02:33:56 pm » |
That's becuase shoutcast can change the servers and then download updates to make your PC compatible without you realising.
Mismatch between servers and fimeware is not unkown. Perhaps the Iphone / flash issue is the best known becuase it hit the News.
The difficulty is mediaplayer makers do not control Shoutcast. Sony control their media portals. They can make sure firmware updates are availabe at the same time as changed servers go online. So when you try to access them you get told "service requires fimeware update", and you update the firmware. Of course if you had waited that would have been done automatically.
You will be pleased to know the Playon!HD has had shoutcast problems in the past. But they didn't start on a fix until after shoutcast had changed becuase they didn't know. Shoutcast dosn't seem bothered to tell mediaplayer makers in advance!
« Last Edit: December 23, 2010, 03:24:55 pm by jer1956 »
copyer
Offline
« Reply #38 on: December 23, 2010, 04:12:37 pm » |
Yesterday, i decided to download 304 again and installed.. radio did not do it, Than, i did install the latest Beta version... gues what? radio worked ! Bud hold on, not all of the generes work. for example: top 40 doesn't work. Will have to wait for new firmware release, the beta is a bit slow and the audio trough optical has faults.. But what a eye candy, i love it......
[500x with FW V404], [500x2 with FW V211] hd500gb intern, 1Tb extern, 2 TB extern Receiver: HarmanKardon 135 Tv: Philips 37pfl6606 led Cisco 3925 [all in one router]
ZwarteMagica
Offline
« Reply #39 on: December 23, 2010, 06:16:08 pm » |
Mede8er 500X firmware 3.0.4 Bootloader : 0000.0202.1026L Board : 1073DD C+ HDD SAMSUNG HD103UJ 1TB
« Reply #40 on: December 23, 2010, 09:06:27 pm » |
My Mede8er (firmware 3.04) doesn't want to show a list of radiostations. It just download this but it doesnt want to show. The only way I could hear radio is by using favourites which I made earler.
Whats going on?
The problem is with the shoutcast server. This is basically a huge index to a library of music channels sourced elsewhere. The med500 is a having problems accessing the index, but the channels are still broadcasting from their seperate sources. If you have a channel stored as a favorite it can still be accessed, but you can't add new channels via the index held by shoutcast.
« Reply #42 on: December 23, 2010, 09:25:19 pm » |
Something to look forward to in the New Year!
ZwarteMagica
Offline
« Reply #43 on: December 24, 2010, 10:42:53 am » |
I did the update to V4 and this worked!! Internetradio (kink FM) is finally playing. So let's see what this Beta version brings us
MartinVDB
Offline
« Reply #44 on: December 29, 2010, 01:29:33 pm » |
Is there any idea when the issue with internetradio will be fixed?
