Pages: 1 [2] 3 4 ... 15   Go Down
Author Topic: Feedback: MED400X/500X V4 Beta 5  (Read 32795 times)
ipodmusicman
« Reply #15 on: December 08, 2010, 09:01:45 am »
UUBee, sajoh if you look at the bug list, you'll see that these issues were not resolved in this release due to their origins within the Realtek SDK.   It seems that this release resolves many issues that are under Sanji's control.
Lets hope that Realtek gets their butt into gear to get Sanji a good SDK release soon.
But I installed the new firmware and I LOVE the 3 level folder support on the video wall.  Now I can justify using it more often since I watch TV shows often on my Mede8er.  It works great, but I still need to put it through its paces.   My only problem is that there is no easy way to populate folder.jpg / about.jpg synopsises for TV Shows.  YAMJ to Mede8er doesn't do this well since it is geared to movies.
Mede8er:  f/w v4beta8
Video: HDMI -> Samsung PS50B550 50" Plasma, 1080p 60Hz,24Hz ON,16:9, Plasma Mode OFF
Audio: Optical TOSLINK -> Yamaha RX-V795a, SPDIF Passthrough / Night Mode OFF
Network:  Mede8er via Ethernet -> DLink AP bridged over WiFi -> ADSL Router.  Win7 PC connected w/ WiFi -> ADSL router.  All 802.11g.
Internal HDD:  1.5GB Seagate HDD formatted w/ Mede8er
Chrissieboy123
« Reply #16 on: December 08, 2010, 11:49:55 am »
WOW, brilliant mede8er yeam really pleased with update. i did it last nite and buzzing with sawting out my media wall and trilogys etc. my next task really to what probs i might get is sawt out getting nas and router.
Duppie
« Reply #17 on: December 08, 2010, 12:52:18 pm »
Just upgrade mine into V4B5 .. Smiley
- bug no [6] .divx and bdiso not playing from movie wall  Fixed in V4Beta5
  found out that, if any movie is play before BDISO, playing BDISO will play last movie, not BDISO.
  Reproduce : Start play BDISO in media library, then stop. goto videowall and play BDISO there, it works.
  Play another movie (any other than BDISO), stop it, goto videowall and play BDISO - it failed - Mede8er will
  play last movie instead of current BDISO.
Resume is off by the way, but if resume is on - resume confirmation dialog still bring mede8er to the last movie instead of BDISO.
Any other has this issue ?
I can confirm this problem as well. This was the first thing I checked after the upgrade.
Lotta
« Reply #18 on: December 08, 2010, 07:51:55 pm »
I liked subtitles colour ( white ) in firmware 3.04.
This one has diiferent colour ( white ), So i changed back to 3.04 : Undecided
Antony Gibbs
« Reply #19 on: December 08, 2010, 09:11:04 pm »
Bug still present from 4b4, when playing DVDISO image from network, subtitles are enabled, but when you press the subtitle button it says they are off, hit enter and they are then turned off.
50" Panasonic, ONKYO A/V Reciever, mede8er, Humax PVR, PS3, PS2, PSOne, Wii, 12Tb NAS
bluntspoon
B8a Tester - X2
...no one really knows...
« Reply #20 on: December 08, 2010, 09:22:19 pm »
FW V4 Beta5 installed seamlessly...
Thanks Mede8er Team
Home Theater Setup:
Samsung LA40C650L1R
Mede8er MED500X2
Mede8er MED400X
leuk_he
« Reply #21 on: December 08, 2010, 10:29:20 pm »
Why not put the image.img in the root of the archive? saves one step in the upgrade instructions.
by the way, the "normal" update procedure works fine.  Wink. I did not manage to save settings, but that could be a Betav4 bug.
There is one small bug  noticed a few days ago, and still exists in beta5:
If you pause a media file where the source is a upnp (tversity ) media stream, and pause it for more then 30 seconds, and unpause it, it plays for 2 seconds. then a message is displayed:
Media is removed
Stop playback
Confirm
Bug  1: The confirm button is not properly aligned in the the box.
Bug 2: The error message does not make sense. The correct message should be that the media server gave a timeout.
Request: Retry to open the media stream, if i do that manually  i can fast forward to the place it was interrupted. If this was done automaticaally in case of server timeouts this would be great.
Request2: prevent timeout by sending some (Huh) kind of keepalive in case of a upnp timeout.  (possible?)
Please fix the Ntfs driver bug, or make ext3 formatting available from gui.
UUBee
Technology is never an excuse for human error.
WWW
« Reply #22 on: December 08, 2010, 11:02:01 pm »
O yes, I love it also. But in my situation I also use Music a lot on the Mede8er, streaming from Internet and MP3 collections. The problem is I don't wat to fiddle around a lot with Sound setup and my Receiver does not support DD7.1 or DTS 7.1 so its a little problem playing movies when the DTS and DD core are not played over SPDIFF. And the value of the video waal is great, but actually, I am more busy switching between sound setups then using the video wall. So 3.0.4 is my firmware until realtec SDK is updated.
2 liters of coca cola, 40 cl of Bacardi....
prettyrabbit
« Reply #23 on: December 09, 2010, 12:03:58 am »
Hi mede8er friends!!! since yesterday i have  updated mine Mede8ers 500x to V4beta5. I did it because my child can navigate through the video wall. it is only failed after I have read and follow the instructions, How I've saved my harddisk as: animation / tinker inside folder.jpg about.jpg tinker.mkv . Can you guys tell me what I have did wrong? many thanks
Domino1999
Senior Member
« Reply #24 on: December 09, 2010, 09:54:50 am »
I guess this now only relates to streamed ISOs now, since ISOs played from internal HDD are fixed and no subtitles play by default.
I've got to say, 3 levels in Videowall is working very well indeed, well done Sanji !
Also, on the old DD units, the power LED turns red to blue as soon as unit is switched on, there's no longer a 5 second delay, so that's also fixed, good job Smiley
Mede8er model: MED500X
Board: 1073DD
Bootloader: 0000.0202.1026
Firmware: V4.04 INC_HD Audio
Internal HDD: WD20EADS 3.5" Caviar Green 2TB SATAII 32MB
External USB HDD: Seagate FreeAgent 1TB
Network: Home Plugs (NETGEAR Powerline AV Adapter with Ethernet Switch XAVB1004 bridge)
Router: BT HomeHub V2
Display: Panasonic TX-L37G15B
Audio connection: HDMI to TV
Audio output devic
pimthunder
« Reply #25 on: December 09, 2010, 04:29:27 pm »
Just upgraded to the new FW, everything went as it should go. Only when i reboot it only gives a blue screen. Anybody knows why?
prettyrabbit
« Reply #26 on: December 09, 2010, 04:31:27 pm »
When I want to resume a movie then it crash very often. The only solution is the unplug the mede8er.
Domino1999
Senior Member
« Reply #27 on: December 09, 2010, 04:38:31 pm »
Resume works fine for me, no crashes/hangs at all. What format are your movies?
Board: 1073DD
Audio output devic
prettyrabbit
« Reply #28 on: December 09, 2010, 04:58:51 pm »
Dvix rmvb mkv
Estherzack
« Reply #29 on: December 09, 2010, 06:53:24 pm »
My movies i had on the Videowall disapeared when I upgraded
Pages: 1 [2] 3 4 ... 15   Go Up
