V4.Beta5 is available for download:
The downloader accepts that they are downloading and installing firmware with noted bugs -
the firmware is stable but not complete for final release.PLEASE NOTE THAT SUPPORT FOR THE PUBLIC BETA WILL BE RESTRICTED TO THE FORUM AND MEDE8ER EU WILL NOT ACCEPT EMAILS OR TELEPHONE CALLS REGARDING QUERIES ON THIS BETA PLEASE MAKE SURE THAT YOU DO NOT HAVE ANY FOLDERS NAMED movie, movies, music, image, images ON YOUR INTERNAL HARD DRIVE as the install makes new ones on the internal HDD during installation. Please only constructive feedback on this beta release, no moaning etc... as this is a beta
MED500X
Mede8er500X_V4Beta5_6_december_2010.rar
http://www.mede8er.org/public_beta/Mede8er500X_V4Beta5_6_december_2010.rarhttp://www.mede8er.org/public_beta/Mede8er500X_V4Beta5_6_december_2010.zipMED400X
Mede8er400X_V4Beta5_6_december_2010.rarhttp://www.mede8er.org/public_beta/Mede8er400X_V4Beta5_6_december_2010.rarhttp://www.mede8er.org/public_beta/Mede8er400X_V4Beta5_6_december_2010.zipUpdate the Mede8er in the normal way via Emergency procedure
Emergency Installation Procedure - Download the latest Firmware from the Mede8er website
- Unrar / Unzip the file i.e. install.img
- Copy this file to the root directory of a Flash Drive
- Plug the flash drive into the Mede8er
- Disconnect the power jack at the rear of the Mede8er then plug it back in
- Now press the on/off button (on Mede8er unit - not remote) - keep it pressed in for 10 seconds and then release
- The LED on the front fascia of the Mede8er with flash red-blue
- You will get a progress bar on your TV display (some TV's will not display this)
- Wait until the Mede8er re boots itself +/- 90 sec
- Re-boot once by pulling power and use as normal
4) If you do not have you own Cover Art download the Demo
http://www.mede8er.org/beta_2010/Mede8er_Video_Wall_demo_images.rar 5)
xxxxxPLEASE READ -- THIS IS VERY IMPORTANT USER GUIDE uxxxxxxx http://www.mede8er.org/artwork/temp/VIDEO_WALL_INSTRUCTIONS_V4BETA5_8Dec2010.pdf6) The custom Mede8er Web Remote has not been included as yet but you can test the default Web Remote as foll
Type the following in your browsers adress bar and change the your-mede8er-ip to the Mede8er actuall IP
http://your-mede8er-ip:1024/Genre Imges in PNG format
http://www.mede8er.org/public_beta/Mede8er_Genre_png.rarGenre Images source PSD file for this who want to add or change or translate.
http://www.mede8er.org/public_beta/Mede8er_Genre_Images.rar Settingsun's_ Media_Browser_ Icons
http://www.mede8er.org/public_beta/Settingsun's_ Media_Browser_ Icons.rarHighlights of V4BETA5
1. 3 Level folder support on Video Wall
2. Compressed MKV headers now supported
3. Thai GUI fixed
4. Vietnamese GUI
5. Discreet "power off" code for learning remotes
6. For specific Bug fixes refer to the bug tracking list
http://www.mede8erforum.com/index.php/board,37.0.htmlMede8er1
