Author Topic: Multimedia Collection Organiser - Updated - New version: 1.0.0.18 (28 Jan 2016)  (Read 79307 times)
Offline SuperDIY
  • Helpful Contribution Status: +0/-8
New version uploaded today (30 Jun 2014).
Changelog extract:
Version 1.0.0.17: (30 Jun 2014)
* Updated file locations - the old file locations are now inaccessible and therefor
  the automatic checking for updates will no longer work on versions prior to 1.0.0.17
* Fixed minor bugs.
Please note that the old download links are inactive and therefor the auto version checking and download links in the application and at the bottom of the old Readme.txt file will not work anymore - these were updated in application version 1.0.0.17 and the Readme.txt file updated on 30 June 2014.
Download link: http://www.spectrumsound.co.za/mmcorg/MMCOrg.zip
Help File link: http://www.spectrumsound.co.za/mmcorg/Help.pdf
Readme file link: http://www.spectrumsound.co.za/mmcorg/Readme.txt
I suffer from CDO... It's like OCD, but in alphabetical order, LIKE IT SHOULD BE!!!
Offline SuperDIY
New version uploaded today (28 Jan 2016).
Changelog extract:
Version 1.0.0.18: (28 Jan 2016)
* Movie Images - Scraping code updated to handle updates on the IMDB- and other
  websites.
* Movie Images - Added option to select the preferred size of the Poster images.
* Movie Images - Improved poster download speed if option to "use first poster image" is
  selected.
* Changed online check / auto check for updates routine.
* Fixed minor bugs.
Offline AKT111
I just downloaded the application on my CPU. My OS is windows 7. I am having a hard time opening the program sometimes it works, sometimes it's just loading and the program won't open. Tried rebooting my CPU, but still the program won't open.
Offline SuperDIY
Hi AKT111
By default MMC checks your internet connection on startup, but this can be switched of on the Help & About screen - after MMC opened and checked the connection, click the "?" button in the top right-hand corner and uncheck both check-boxex in the center of the window, and click close.
MMC uses IE's internet configuration as per the readme.txt file.  In other words, IE needs to be installed on your computer and you must be able to browse the internet using IE, e.g proxy configuration etc. must be set correctly to enable browsing.  If IE is not installed or not configured to browse the internet, MMC's "internet connection checking" will timeout after a while, but sometimes it might crash and hang the application as well.  If you have a terribly slow internet connection, the "internet connection checking" procedure might take quite a while and the controls in MMC only activates once the "internet connection checking" procedure has completed and therefor it might seem that it is hanging.
