Pages: [1] 2   Go Down
Author Topic: Tool to fix compressed Headers on MKV files  (Read 23393 times)
Administr8or
« on: October 27, 2010, 06:59:17 am »
Pls find a simple tool to fix compressed headers on MKV files that only play audio
Instructions
1) Download latest version (currently version 0.6.0) of mkwdclean from http://sourceforge.net/projects/matroska/files/mkclean/
1) Unrar or Unzip and you will see the file mkWDclean.exe
3) Drag the problem MKV file into mkWDclean.exe
4) It will make a new MKV that will play fine in the Mede8er
Retrovega
« Reply #1 on: October 27, 2010, 02:47:03 pm »
Will this tool fix the problem where some the mede8er only plays the audio of some mkv files?
« Reply #2 on: October 27, 2010, 04:30:07 pm »
yes, as that is caused by default enabled header compression it will.
Retrovega
« Reply #3 on: October 27, 2010, 06:11:52 pm »
great thanks, downloaded it, and now i have no idea what to do with it. Don't have a C compiler, nor do i know how to build coremaker.
A little help.
« Reply #4 on: October 27, 2010, 06:30:31 pm »
You use the big green download button. The list below consists of source files and builds for other operating systems.
Retrovega
« Reply #5 on: October 27, 2010, 08:51:46 pm »
using win7 64 bit. Downloaded the win 32 version, i try running th file, and only cmd window pops up and disappears after a split second.
Tried running the file from dos, and when i type it in as required, it says it cannot find the specified file.
Sorry for being a noob, but not sure how all this works.
pikka68
Italy
« Reply #6 on: October 27, 2010, 10:36:53 pm »
Byez... Pikka68
VIETHD
« Reply #7 on: October 28, 2010, 03:37:52 am »
drag the mkv file  into the mkWDclean.exe icon, a window appears and the process start. That's all.
Mede8erViet
« Reply #8 on: October 28, 2010, 12:53:39 pm »
Hi guys, I got this problem  to day with this tool-.-
need some help
edutch
« Reply #9 on: October 28, 2010, 01:02:30 pm »
Same here tool stops working after starting part 2 of his process
Med 600X3D (v1.0.5) & 500X (V4.05)
Ps3 & Samsung BD-E5500 Blu ray
Synology DS213 & Qnap TS109Pro
Netgear WNDR3800 & D-link DGS1008D gigabit switch.
Plasma Samsung PS60E6500
Onkyo NR TX 709
Sypro
« Reply #10 on: October 28, 2010, 01:05:00 pm »
have the same issue.
Retrovega
« Reply #11 on: October 29, 2010, 08:42:21 am »
Thanks will try the drag drop later today.
reynold
« Reply #12 on: October 29, 2010, 10:42:03 am »
after it fixed the mkv file, will there be any effects on the video and audio quality of the movie? i noticed that after the process, i noticed that the file size was reduced. May sample file of  2.5gig became 1.8gig.. is this natural? thanks..
« Reply #13 on: October 29, 2010, 11:11:10 am »
The file should get slightly bigger as the header has to be re-embedded throughout the MKV.
reynold
« Reply #14 on: October 29, 2010, 11:33:20 am »
That's what i've expected... but my file got smaller, this is weird. Can someone explain why? Thanks.
...some info became smaller after the process...
File Size: from 2.5gig to 1.8gig
Overall Bitrate: from 2,803 kbps to 2,017kbps
Video Bitrate: 2,354 kbps to 1,529 kbps  (Nominal Bitrate is still set to 2,354kbps)
Bits (Pixel*Frame): 0.107 to 0.069
« Last Edit: October 29, 2010, 11:42:13 am by reynold » Logged
Pages: [1] 2   Go Up
