The Mede8er MED10WF WiFi 802.11N Dongle can be used on your Windows PC. This dongle does require a specialized driver to be installed. You can also use two MED10WF dongles if you want to connect via WiFi in Ad Hoc mode.
Mede8er WiFi Dongle "N" Driver for Windows Rev 090525Note: IEEE 802.11n will be released on Jan 2010, however, there is already various AP and wireless routers using draft N standard. The draft N standard prohibits using High Throughput with WEP or WPA2-PSK as the unicast cipher, and your data rate will drop to 54 Mbps (802.11g) which is normal. Please try other encryption methods (WPA-PSK), or choose to configure an unsecured profile.
