For images you can use an SD card that stay in the mede8er. That way you can have them without needing a harddrive in your mede8er and or have something sticking out on the side.
I got the genre setup correctly now, but do i need to put all my movie's hand by hand in the right genre folder? Or can this be done with another tool/program that does this job all by itself?Thx.
There is already a lot on the web....When you use Google for example:http://www.mediabrowser.tv/forum/viewtopic.php?f=2&t=1880Only need to convert this to jpg.
I'm not sure the wife would go for you Chick Flick icon. Hugh Grant and Handbags would be more like it! Perhaps you mean that certain kind of movie with just chicks in it that blokes like?
