Author Topic: Genre Icons for the Video Wall  (Read 158551 times)
Offline mareems
Re: Genre Icons for the Video Wall
« Reply #30 on: November 15, 2010, 07:50:14 pm »
very nice thanks for sharing
« Last Edit: November 15, 2010, 09:32:04 pm by mareems »
Mede8er500X V4.05 with in disk WD15EArS 1.5 TB (HDMI 1.3 to AV Receiver)
Xtreamer Pro  with in 2 disk WD2Ears 2.0 TB (HDMI 1.3 to AV Receiver)
TV LED LCD Samsung "UE40B8000"
AV Receiver Onkyo "TX-SR 607" (HDMI 1.3 to TV) & Harman/kardon Speakers 7.1
Lg 190 Blue-ray (HDMI 1.3 to AV Receiver)
TV decoder Humax ihdr5050 C in disk Samsung 1.0 TB(HDMI 1.3 to AV Receiver)
Ext usb disk 2 x Samsung
Offline Sypro
« Reply #31 on: November 16, 2010, 04:27:29 pm »
http://rapidshare.com/files/431221452/genres.rar
Added War and Drama. I however can't find a decent picture for fantasy. When i think fantasy, i instantly imagine Lord of The rings, but i can't find any decent pic that describes the word in one eye sight.
Offline wrestlemagic
« Reply #32 on: November 20, 2010, 03:02:35 am »
HI there, Just wondering if somebody could help please.
I have downloaded settingsuns genre art files. Converted them to jpg and put them in a folder called videowall on my mede8er.
I'm having a lot of trouble trying to get the pictures to show on the videowall. When choosing what icon I would like to use for each shortcut, I seem to only be getting a blank folder and no artwork.
Thanks for any help.
Best wishes
Wrestlemagic
Offline rickringers
« Reply #33 on: November 20, 2010, 12:32:52 pm »
did you make it the right size , no more than 75k ;)
Offline rickringers
« Reply #34 on: November 20, 2010, 12:34:45 pm »
i would like to have the icons that are posted , but i can,t get it from rapishare , anyone? ;)
« Reply #35 on: November 20, 2010, 01:43:25 pm »
Hi there,
I used AVS to convert, but do not understand what you mean by right size?...Are they not already set as is?
How do I make them the right size?
Thanks for your help.
Best wishes
Wrestlemagic
Offline Sypro
« Reply #36 on: November 20, 2010, 02:15:20 pm »
Obviously as i use them myself, i made them for myself.
I also uploaded it again as it seems that rapidshare is useless.
http://www.2shared.com/file/7BC42VD9/genres.html
« Reply #37 on: November 21, 2010, 10:34:01 am »
I don't seem to be able to download this.
Can someone please tell me how to resize my original downloads?
Many thanks
Best wishes
Wrestlemagic
Offline avman
« Reply #38 on: November 21, 2010, 06:59:52 pm »
Wrestlemagic
Inside the panel, you need to click on    "Save file to your PC: click here"
   File URL:
Last downloaded: 2010-11-21   Save file to your PC: click here
I've just downloaded it without problems.
Offline markt1891
« Reply #39 on: November 21, 2010, 08:03:23 pm »
I haven't tried v4 yet but have a quick question about genre art for the videowall which I hope someone can answer...  I don't have an internal disk or external USB drive attached to my Mede8er.  I stream everything over the LAN from a Windows Home Server (which works great  :)).
From what I have read it seems the only way of customising the genre artwork is to install a hard disk or plug in a USB drive.  If I use a USB drive to store the genre images can this be removed once they are configured or does it need to remain permanently attached?
Thanks,
Mark.
MED500X f/w v4.04 / MED400X2 f/w v3.0.1 / Denon AVR-F100 / 1gb Cat5e / Netgear GS716T-200 / Windows Home Server PP3 2 x 2tb / Panasonic TX-L37V10
« Reply #40 on: November 21, 2010, 09:20:44 pm »
Thanks,
Mark.
Just read the V4beta4 video wall instructions that come with the firmware.
No need for usb disk or internal mede8er disk. Cover Art Video Wall will also work from Samba shares or NFS shares.
Offline markt1891
« Reply #41 on: November 21, 2010, 09:39:57 pm »
Hi Massbommel,
I have read the videowall instructions.  The videowall instructions state:
22) To apply custom artwork for the Genre covers you must create artwork in PNG/JPG format to
pixel size of 156 x 233 pixels. Create a new folder in the root of your Local Hard Drive or USB
Stick called “videowall” and copy your images to this folder
. The Mede8er will now allow you to use
your own custom images for the Genre links on the Video Wall.
Are you saying that I can disconnect the USB disk after selecting the images?  Sorry if I am misunderstanding something but the videowall instructions don't clarify this point.
Thanks.
« Reply #42 on: November 21, 2010, 09:40:42 pm »
   File URL:
I'm still having problems. Wuill not download on 2 different computers. It will only keep sending me back to the original page.
Best wishes
Wrestlemagic
« Reply #43 on: November 21, 2010, 10:06:11 pm »
Hi Massbommel,
Thanks.
Thats only needed when you want to change the standard Genre Icons to personal ones.
If you use the standard Genre Icons that come with V4, then there is no need for an internal disk or usb stick/disk. Movie cover art will still work on the video wall.
edit:: yes, the disk or stick needs to stay attached if you want personal customized Genre Art Icons.
« Last Edit: November 21, 2010, 10:10:44 pm by Maasbommel »
Offline Sypro
« Reply #44 on: November 21, 2010, 10:07:28 pm »
Im getting really tired of these [CENSORED]ty upload sites.
http://www.mediafire.com/?thhdac29b2up1bt
For images you can use an SD card that stay in the mede8er. That way you can have them without needing a harddrive in your mede8er and or have something sticking out on the side.
