Pages: 1 ... 15 16 [17]   Go Down
Author Topic: Genre Icons for the Video Wall  (Read 48465 times)
michelu
« Reply #240 on: March 12, 2012, 08:54:37 pm »
Hello,
I can not seem to get the new icons to work.
Got a 500x2
made a "videowall"-folder in the root of the HDD (in lowercase)
put the images in there.
someone wrote that it should be jpg so i tried.
tried png.
all below 75k
156x233 px in size.
restarted the player but still, only the standard images show.
What am i doing wrong  Huh Huh Huh
« Reply #241 on: March 12, 2012, 08:59:29 pm »
You trying to set up an X2 as if it's an X1.  Go to the X2 section and read in the latest manual the section on skinning (page 28).  With an X2 you can skin icons into  flash..that way they are avaialble if you chose to boot to  favourites.
« Last Edit: March 12, 2012, 09:06:13 pm by jer1956 » Logged
michelu
« Reply #242 on: March 12, 2012, 10:17:55 pm »
Oeps,  Embarrassed  thanks. found the item.
i'll try thanks
voostro
« Reply #243 on: April 06, 2012, 08:59:41 am »
Hello all,
Can anybody help me with a genre image of Thomas and Friends?
I know there are a lot of images on the web, but can't find this image.
Hope anyone of you can and will help me!
Thanks!
Voostro
GlynRS2
X2 Skin Designer
« Reply #244 on: April 06, 2012, 10:17:16 am »
Hello all,
Thanks!
Voostro
Are these the sort of thing you were after?:
 Wink
Download all my genre icons for the Mede8er videowall from this thread (updated 05.02.2013 & includes music genre icons)
Download all my ThumbGen templates for the Mede8er by clicking here (updated 01.12.2011)
Tibinator
« Reply #245 on: April 11, 2012, 02:10:27 am »
hi, i'm new Cheesy (sorry my english, im from chile (sudamerica)
please make "ANIME" and "DORAMAS" Sad thanks.
demonrecords
WWW
« Reply #246 on: April 11, 2012, 06:00:20 am »
As far as I know there is an ANIME one in his packages if you download them.
Why do you keep on watching the porno after you came?
Basil Plumley
« Reply #247 on: April 14, 2012, 05:23:15 pm »
Could somebody please lay this out in simple terms for me please...?  How do I get the custom genre icons onto my X2?  And please don't say read page 28 of the manual as I've done that hundreds of times - got a folder named "genre" on my network (though on my mede8er, if I open it I can't see anything though can see all the icons on my PC), pressed menu, hit set to skin, reboots...no new genre icons!
Driving me a bit mad now - worked fine on my 500X which I'm beggining to wish I'd kept... Roll Eyes
« Reply #248 on: April 14, 2012, 05:29:59 pm »
Have you a parent folder for the genre folder...it's that parent folder that you skin....see item 25:-
http://www.mede8erforum.com/index.php/topic,8213.0.html
I havn't tried over the network. It's easier  with a USB stick,..as once the icons are skinned the stick can be removed.
« Last Edit: April 14, 2012, 05:36:46 pm by jer1956 » Logged
Skylinc
B8a Tester - 1000X3D
« Reply #249 on: April 14, 2012, 05:41:23 pm »
Hi Basil
What you are meant to do is this:
1. Create a folder, call it anything you want (I'm going to refer to this folder as myIcons)
2. Browse to the location of myIcons, but do not go into the folder
3. With myIcons highlighted, click on Menu, then Set Skin
As jer said, using a folder on a USB stick might be a lot better than trying to do it over the network.
Audio: HDMI > LG 42LW4500
Basil Plumley
« Reply #250 on: April 15, 2012, 03:05:40 am »
OK guys - I think I've got it...at the moment I have a folder called genre on my network - in that folder is the icons.  I try to skin tha folder and nothing happens - what I need to do is put that folder inside another folder (the parent folder), go to the parent folder, select set to skin and it'll skin what's in the folder in the parent folder...
Right...? Huh Grin
Skylinc
« Reply #251 on: April 15, 2012, 08:24:42 am »
Hi Basil
Yes. Inside the myIcons folder should be the 'genre' folder with all the icons
Chrissieboy123
« Reply #252 on: July 24, 2012, 01:43:22 pm »
Hello, it has been a while since i have been on here so a little out of the loop. but i am now back on track for sawting out my NAS etc. but i did have a favout to ask, i was wondering if over four icons some new ones could be done that say Movies A - F, then Movies G - L and then Movies M - S and lastly Movies T - Z. would this be ok
Pages: 1 ... 15 16 [17]   Go Up
