Author Topic: Genre Icons for the Video Wall  (Read 150283 times)
Offline stijn
Re: Genre Icons for the Video Wall
« Reply #15 on: October 10, 2010, 12:57:30 pm »
anyone knows where i have to put the icons on?
can i putt them on an external drive or? i dunno
nobody knows?
Offline the-osiris
« Reply #16 on: October 10, 2010, 02:01:52 pm »
just create new folder in mede8er called videowall or VIDEOWALL  ;)
MED450X2 V2.1
MED1000X3D V2
LG 42LE5500 HDMI
Offline stijn
« Reply #17 on: October 10, 2010, 04:06:39 pm »
How do you mean in mede8er? i dont have a hdd inside mede8er
Offline the-osiris
« Reply #18 on: October 10, 2010, 05:04:18 pm »
then you could create in your root folder of external media (USB)
MED450X2 V2.1
MED1000X3D V2
LG 42LE5500 HDMI
Offline stijn
« Reply #19 on: October 10, 2010, 05:15:05 pm »
ok thx, will try it
Offline stijn
« Reply #20 on: October 16, 2010, 07:58:17 am »
that doenst work...
i made it like that but i dunno how i should select it then, it doenst show up in the list of available icons
« Reply #21 on: October 16, 2010, 09:00:10 am »
that doenst work...
Where did you made the folder videowall, on internal disk or on usb disk?
Offline stijn
« Reply #22 on: October 27, 2010, 11:17:27 am »
usbdisk
i had no internal one at that time (now i do)
Offline sjweemie
« Reply #23 on: October 27, 2010, 07:16:51 pm »
hi got a problem had the videowall set up just right with custom genre art and al working perfectly. and for one reason a couple of weeks later my genre art was gone on the videowall, i tryed to re-apply then and i get the standerd art that was installed on it. so i hooked it up to my laptop and checked. i got a file callen VIDEOWALL inside there are my custom genre art in jpg.  they are not bigger then 75K  size 156x232.   i tryed to chanche then to png but that didnt help.  i dont know what the problem is, it worked al fine before. :)
grtzzzz remy
Offline stijn
« Reply #24 on: October 29, 2010, 10:55:09 am »
usbdisk
any comments?
Offline Sypro
« Reply #25 on: November 15, 2010, 04:14:03 pm »
I made some icons for myself. You can download them if you like them yourself. The psd file is included if you want to add something yourself. Nothing special i just thought some might like it to use it aswell.
http://rapidshare.com/files/431028114/genres.rar
updated the adventure pic with the right spelling...
« Last Edit: November 15, 2010, 04:42:43 pm by Sypro »
Offline MarioB
  • B8a Tester
  • If It Bleeds, We Can Kill It!!!!
« Reply #26 on: November 15, 2010, 04:29:21 pm »
I made some icons for myself. You can download them if you like them yourself. The psd file is included if you want to add something yourself. Nothing special i just thought some might like it to use it aswell....
Very nice, thanks...
Offline Sypro
« Reply #27 on: November 15, 2010, 04:39:08 pm »
lol i actually failed hard on the aventure part i'll change it
« Reply #28 on: November 15, 2010, 06:00:13 pm »
Nice, thanks for sharing.
Offline Sypro
« Reply #29 on: November 15, 2010, 07:26:50 pm »
Think, i'll make a war and thriller one tommorow. As i seem to be missing those.
