Author Topic: Issues with updating V4 beta4 from a Mede8er with 17L bootloader.  (Read 22644 times)
Offline cdx873v
Re: Issues with updating V4 beta4 from a Mede8er with 17L bootloader.
« Reply #30 on: January 30, 2011, 09:57:32 am »
Ey, guys i had the same issues updating,
also tried "hp format tool" but stil no luck,
just use a different usb stick , i tried it with a old 128mb (slow stick) formatted in "fat32" with "default allocations size"
works 100%
but wil be going back to 3.0.4, because of i have a Sony KLV-40W550A so i also have the audio message that apears "unsupported auio " on the beta4, (i can fix the big green bar problem by  unplugging and reconnecting the hdmi cable and the small green bar by setting the digital audio to HDMI and back to SPDIF)
and cos i'm using the SPDIF with my audio system i dont want to keep having to change the audio output to 2ch downmix to get my stereo content to play through my system
cant wait for a final release
This is ridiculous, but it acctually worked for me too, lol. don't know if it was the 7 updates or the usb stick though
Offline asenmmh
« Reply #31 on: September 13, 2011, 02:15:48 pm »
hi all...
many tray any way from this forum, but same problem.
i use Flash disk  SanDisk 4GB
i have remove the partition and format use HP format tool
and i'm copy install.img ( v. 4.0.4 )
but,  in 3/4 process .... Stack again...
reboot ....
stack again.... again and again...
any idea ???
« Reply #32 on: September 13, 2011, 08:05:03 pm »
You bootloader update fails somehow, and therefore it get stuck at 3/4.
Try first to install V4:
http://www.mede8erforum.com/index.php/topic,4275.0.html
If that is succesfull, then try 4.0.4 again.
Offline Bacon
« Reply #33 on: July 11, 2015, 03:41:13 pm »
Hey guys
Got a mede8er med500x  bucks can not update it what so ever tried 3 different flash drives and different formats tried diffrince v of the update both from the boot and from the menu please can someone help me. I've even removed the hdd I'm still running version 1.0 (don't laugh ) and boot loader IIKE.0303.0016.
