Author Topic: Issues with updating V4 beta4 from a Mede8er with 17L bootloader.  (Read 23220 times)
Offline Dyce
Re: Issues with updating V4 beta4 from a Mede8er with 17L bootloader.
« Reply #15 on: October 02, 2010, 05:36:09 pm »
Used the format tool.
Also took hdd out.
Succes!
Offline Danmarc
« Reply #16 on: October 02, 2010, 05:44:56 pm »
The USB stick was formatted with the HP soft.
Later edit: VICTORY.
Reverted to 3.0.4. and after that, started the update from the beginning with the FW from zip form.
I placed the USB stick (formatted FAT 32 with the HP soft) in the upper USB slot of the Mede8er (I remember I saw this issue somewhere but maybe I am wrong).
Also, allot of patience, especially when system reboots. Even if you have the feeling that is blocked, just let it do the job.
Thanks.
« Last Edit: October 02, 2010, 06:19:45 pm by Danmarc »
Offline leuk_he
  • B8a Tester
« Reply #17 on: October 02, 2010, 08:21:00 pm »
I am sure i did my upgrade with the stick in the lower slot, while i left the usb wifi in the top. No problems (after i figured out that the archive contained a directory with the image.* instead of root)
Please fix the Ntfs driver bug, or make ext3 formatting available from gui.
Offline snoegeleur
« Reply #18 on: October 02, 2010, 09:37:08 pm »
Started working when i formatted my usb stick to ntfs and it didnt work on etx4 (didnt get the patch install screen)
Offline LightAds
  • Until that time
« Reply #19 on: October 03, 2010, 06:09:18 am »
I'm trying to download the patch from the link sent to me via email but i'm getting "File not found". I have downloaded the firmware no probelm. Is the 17L patch being removed or being updated?
Alive & Kicking
Craig
Offline the-osiris
« Reply #20 on: October 03, 2010, 06:29:01 am »
It's updated - link inside email, especially for updating bootloader has error, mede8er has updated those files ..
http://www.mede8erforum.com/index.php/topic,3165.0.html
MED450X2 V2.1
MED1000X3D V2
LG 42LE5500 HDMI
Offline LightAds
  • Until that time
« Reply #21 on: October 03, 2010, 01:22:31 pm »
Thanks for the heads up. Downloader Patch 17L and V4Beta4 installed successfully.
And now for the video wall..............
Alive & Kicking
Craig
Offline rx4age
« Reply #22 on: October 03, 2010, 04:10:08 pm »
I have tried everything, reboot  USB, disconnected the HD, tried both USB ports and still no update. The previous update a few months ago was a breeze, dont know what is wrong this time..... :(
Offline JIGSAW
« Reply #23 on: October 03, 2010, 04:18:24 pm »
Well then I guess it's a GOOD idea to re-send everyone a new mail with the updated information  ;)
Offline rx4age
« Reply #24 on: October 03, 2010, 06:11:46 pm »
At last it is installed, dont know what the problem was, but thanks anyway
Offline Freddy-M8
« Reply #25 on: October 04, 2010, 07:48:22 am »
Bootloader Patch 17L and V4Beta4 installed successfully.
Used .rar and formatted USB.
MED500X board 1073DD f/w v4beta4 loader 1026 -  Samsung HD203WI 2TB   (M8R formatted)
Audio:  Optical output > JVC RX-E112rsl - SPDIF Passthrough  / Nightmode OFF
Video: - HDMI output > LG 42" Plasma LG42PX3RVA
Wired Network: Cat 5e / fix IP / Router LynkSys WRT 54G
PC Q8200
Multiboot: Win 7 Ult. 64 bit /  Vista Business 32 bit / Win XP Pro SP3 32 bit .. + Norton360
Offline czr1803
« Reply #26 on: October 05, 2010, 11:33:32 pm »
after struggling to install , what worked was simply using the system update option form the system menu 8)
Offline IceQB
« Reply #27 on: October 12, 2010, 08:37:16 pm »
Same here, struggled - removed HDD, reformatted USB with tool.
Then just ran from system update option in menu. Worked.
Offline HungryPanda
« Reply #28 on: October 15, 2010, 11:57:43 am »
I tried at first with a Maxell 4Gb pen and could not update so changed to a Kingston 2 GB pen and it updated perfectly
Offline Guyver
« Reply #29 on: November 14, 2010, 08:54:30 pm »
Ey, guys i had the same issues updating,
also tried "hp format tool" but stil no luck,
just use a different usb stick , i tried it with a old 128mb (slow stick) formatted in "fat32" with "default allocations size"
works 100%
but wil be going back to 3.0.4, because of i have a Sony KLV-40W550A so i also have the audio message that apears "unsupported auio " on the beta4, (i can fix the big green bar problem by  unplugging and reconnecting the hdmi cable and the small green bar by setting the digital audio to HDMI and back to SPDIF)
and cos i'm using the SPDIF with my audio system i dont want to keep having to change the audio output to 2ch downmix to get my stereo content to play through my system
cant wait for a final release
