Nicap
Offline
« Reply #90 on: October 02, 2010, 11:12:16 pm » |
The videowall is great. I've put many movies in the genres, but can it be enhanced in someway? As a lot of movies fall into more genres, would it be possible to make shortcuts to movies and put the shortcut in the other genre(s)? I tried it this afternoon, but it doesn't work right now.
V4 is really good work of you guys. Keep up the good work for the final release :-)
SwedenDude
Offline
« Reply #91 on: October 02, 2010, 11:16:15 pm » |
Anyone else had this yet, have 23L bootloader, when listening to a internet radio station then press return button the mede8er hangs and reboots?
Tv: Sony 40EX500 (hdmi <-> mede8er) Receiver: Pioneer (non-hdmi, toslink connected) PC: Windows 7 Pro 32bit Router: Netgear 3700, Connection: 10/100 wired cat5 Mede8er: 1073DD C+, 23L, HDD: WDC WD15EARS-00J 1,5TB FW: v4b4
« Reply #92 on: October 02, 2010, 11:19:15 pm » |
If you have updated to V4Beta4 you will have bootloader updated to 26..... So is your question regarding to this V4BETA4 or is it for another release?
SwedenDude
Offline
« Reply #93 on: October 02, 2010, 11:29:52 pm » |
System info says still 23L and yes its v4b4 im currently using, looks great.
zdravo
Offline
« Reply #94 on: October 02, 2010, 11:34:44 pm » |
Hi zdravo
Downloader your rar but it is corrupt. Maybe you can re upload.
Hy I just downloaded it and it's OK. But I am just uploading new the same thins under different name. So, here it is: http://www.4shared.com/file/1P_gF3hY/My_movies_A-C__originals_and_r.html
Mede8er FW v4 - 25 January 2011 with Seagate 1,5TB connected by LAN to PC by HDMI to TV + Panasonic 32" TX-L32S10E Full HD LCD TV Win 7 64bit on Q9550 8GB RAM + Linksys WRT54GL FW DDWRT v24 sp1 10020
949BFN
Offline
« Reply #95 on: October 02, 2010, 11:45:05 pm » |
Thanks for the response. I have tried what you suggest, but will go throught it all again (incluing a re-download of the files(for a 3rd time!!)) and report back.
I got it working. A deep format of the usb stick did the trick. I've used the particular usb stick for at least 2 previous upgrades without any issue, but for some or other reason, I could not get it to work until I formatted the stick. Thanks for your patience Maasbomme. The new interface looks awesome. It is fairly slow however. Congratulations to the developers and testers.
Mede8er 400, 500 & 500X2
« Reply #96 on: October 02, 2010, 11:59:52 pm » |
Thanks for this feedback. The difference with this 17L patch update compared to other updates is the bootloader changing to version 26. Maybe that is the reason that usb sticks with a hidden partition (e.g. u3 partition) are not working for this proces. The specific format tool removes those hidden partitions. Regarding to the speed of the movie wall: be sure that your folder.jpg files are not to big, or it will slow down the movie wall. Please read the Video Wall instructions regarding to advised folder.jpg size and about.jpg size: http://www.mede8er.org/public_beta/VIDEO_WALL_INSTRUCTIONS_V4BETA4.pdfAnd be sure that you have loaded the latest Beta4 version after the patch install, check the info screen to verify you have the right version. When you only load the patch you will have a lower version. regards, Maasbommel
« Reply #97 on: October 03, 2010, 12:07:06 am » |
Hmm, media library is not stable for me in beta4. I get hangs when navigating through the folders, at not repeatable points. I will try to reproduce, but it is not celar to me yet when it hangs. The remote becomes non-responsive, and sometimes the rotating "8"is stopped in its tracks.
NAS/Ftp/telnet are still working at that moment, but there is no other option that to power off or reboot via telnet.
I did not yet manage to get the video wall working. (Folders named video_ts are browsed instead of played, and maybe i need to read the manula 3 or 4 more times, which is an indication it still is too complicated)
And is this happening in standard setup or modded setup with modded ext3 partition? Just read you are using ext3: http://www.mede8erforum.com/index.php/topic,1471.msg21202.html#msg21202
Kabelventje
Offline
« Reply #98 on: October 03, 2010, 01:19:12 am » |
When set HDMI and Optical out to passtrough, audio is ok. But no internet radio !! Optical has to be set in 2CH Downmix. Then internetradio if ok but movies are only 2CH instead of 5.1......  This was not the case with v3
Labrador retriever Dikke rode Kater Kleine zwarte Boskat Radio Televisie Twee Kinderen
UUBee
Offline
Technology is never an excuse for human error.
« Reply #99 on: October 03, 2010, 05:00:31 am » |
Everything works fine here, and it is still a Beta Release, but I love to see the final, KEEP UP THE GOOD WORK! But here are some annoyances: Firmware 3.0.4.- HDMI Audio -> Off
- SPDIF -> Passthrough
Worked for me because I never use TV Set for Audio or Sound. Firmware 4.0 beta 2Option 1:- HDMI: Downmix 2CH
- SPDIF: Passthrough
Not 2Chan on audio set and no 2CH movies on audio set, no MP3 on audio set, sound only on TV Set, not workable for me Option 2:- HDMI: Passthrough
Not 2Chan on audio set and no 2CH movies on audio set, no MP3 on audio set, sound only on TV Set, not workable for me Other options where SPDIF is downmixed 2ChanNot usable in any means for me I see this is addressed in firmware issue number 1]. So I think in the final it is fixed. Now flashing back to 3.0.4 because box is unusable when this issue is not fixed.
« Last Edit: October 03, 2010, 05:11:56 am by UUBee »
2 liters of coca cola, 40 cl of Bacardi....
ThuNd3r
Guest
« Reply #100 on: October 03, 2010, 08:43:51 am » |
I have a little bit testet the new Beta4 Realease and i post some issues: - Internet Radio doesent work. When i will play a radio station the media says "download failed" - When i will play a movie (avi or mkv) it takes 5 seconds before the movie starts. In 3.0.4 i dont must wait so long  -I have no sound on amp when i have a 2 channel movie and SPDIF is set to Multichannel. I must set it to 2 channel.Then i have sound. In 3.0.4 i dont must change the settings. -When iam in a movie and i press the setup button the menu is not transparent. -Over network i cant access to my pc. It always will be have a username and password. Or is it a windows 7 problem? Have tried some settings but ist doesnt work for me. Thats it
zaimben13
Offline
i love mede8er ! big up for south africa!
« Reply #101 on: October 03, 2010, 09:26:20 am » |
hi all! so as i said i installed the new Beta firmware on the box of my friend but due to the beautiful interface, i aslo decided to install it on my own box! i think some issues that have already been listed in the beta issue list are still in this beta 4! - slower interface i mean, when im on synopsis view, and i click ok, the film lounch after 5-6 seconde...(less in 3.0.4) -some freez of the interface when i plug a external hardrive on usb port: here i got a lot of films that are displayed for somme second with artefact (at the begining) and no audio....) 3.0.4 it was nice but here not! - i didnt used the internet radio nor the network system cause i do not use this..... -i prefer to revers back to 3.0.4 and wait for the last stable release in fall october or even half of november ! keep up the good work! video wall looks fantastic!
regards, zaimben!
med500x firmware 4.0.4 2to hdd inside +2to external hdd ps3 slim 250go xbox 360 elite SLIM 250go lcd LG 27 inch full hd waiting for MED1000X3D release in Europe
stijn
Offline
« Reply #102 on: October 03, 2010, 09:33:17 am » |
i have problems installing the new firmware with the emergency procedure.. it says installing V4.. then i see couple of blocks but then it freezes...... any ideas?
the-osiris
« Reply #103 on: October 03, 2010, 09:34:28 am » |
I have also noticed last night, some of my movies also has green artefact at the beginning, but I will try several again and check/compare the mediainfo log .. I hope not Mede8er bug ..
djphatic
Offline
« Reply #104 on: October 03, 2010, 09:49:09 am » |
- Internet Radio doesent work. When i will play a radio station the media says "download failed" Make sure you have set your Default Gateway/DNS correctly. Mine kept defaulting to 127.0.0.0 (I think) when it should have been 192.168.0.1. - When i will play a movie (avi or mkv) it takes 5 seconds before the movie starts. In 3.0.4 i dont must wait so long  I have the same, though I wasn't aware this was an issue as I have only just got the player and updated to the latest firmware. -I have no sound on amp when i have a 2 channel movie and SPDIF is set to Multichannel. I must set it to 2 channel.Then i have sound. In 3.0.4 i dont must change the settings. Can you not set it to passthrough? -Over network i cant access to my pc. It always will be have a username and password. Or is it a windows 7 problem? Have tried some settings but ist doesnt work for me.
Most likely Windows 7 issue (though could be due to the your first point too). You need to disabled password access in the Network and Sharing Center. Hope that helps.
