please, im trying to install this beta to a friend which absolutely want this release candidate installed on his box! im actually in his home with my usb drive, but i do not know by which file to star??? (i do not want to instal it on my own box...prefer to wait for final release) but there is to much file here im confused im scared to make a ******!
please, i think he got 17l boot loadert
so am i right here???
1/ instal the patch boot loader 17l (the two file on the root of his usb)
2/ follow emergency procedure
3 / put the med beta 4 file (one file : instal file) in the root of the same usb...
4/ same emergency procedure,???
or do i have to put both patch loed file and beta 4 instal file in the same root usb??? please some help cuz im scared....
Follow as stated in the instructions for L17 then, instructions are clear....
1) Check your Mede8er Bootloader Version in the Setup Menu.
If you have 17L go to point 2.
If you have 23 go to point 3
2) Instructions for updating from Bootloader 17L XXXXX UPDATED XXXXXX
a) Download 0017L_bootloader_patch.rar AND Mede8er_V4Beta4_2_October2010.rar (OR zip equivalents)
b) Unrar/unzip the file 0017L_bootloader_patch.rar or 0017L_bootloader_patch.zip and you will find 2 files inside.
install.img and install.dat
c) Copy these files to the root of a USB drive
d) Install via Emergency Procedure.
--- On the first stage you will see the patch install on the screen
--- then the Mede8er will reboot
--- Next you will see BETA2 install on screen and a yellow box after half of progression bar stating it has to reboot
--- then another reboot
--- then again it starts to install BETA2 and finishes with install complete and reboots
THE PROCESS IS NOT COMPLETE SO PLEASE CARRY ON
e) Delete the two files install.dat / install.img on the USB stick
f) Unrar/Unzip the file Mede8er_V4Beta4_2_October2010 and copy the install.img to the root of the USB stick.
g) Update the Mede8er in the normal way via Emergency procedure
