Pages: [1] 2 3   Go Down
Author Topic: Logon Fail!  (Read 4784 times)
Frknzmn
« on: September 25, 2010, 03:14:37 pm »
Product & firmware version: Mede8er MED500X f/w v3.0.4
Media Source: Wired Network > Windows 7
The problem is i can't connect to my 1.PC but i am able to connect to my 2.Notebook using my username,password
Workgroup : 1.PC   2.Notebook
Turned off windows firewall,router firewall,antivirus firewall still cant login
These are the screenshots of my 1.PC homegroup/sharing settings which are the same on my 2.Notebook
any ideas?
« Last Edit: September 25, 2010, 09:31:00 pm by Frknzmn » Logged
« Reply #1 on: September 25, 2010, 04:03:43 pm »
?? Which one is the screenshot from the PC that is able to connect to?
The lower one is different then the upper. File/Print sharing disabled? Then sharing a folder will not work.
Frknzmn
« Reply #2 on: September 25, 2010, 04:05:38 pm »
these are all screenshots of 1.PC which i can't connect to.  the 2nd screenshot is home network settings and the 3rd is public network settings
Frknzmn
« Reply #3 on: September 26, 2010, 07:26:43 pm »
still can't login.....  anyone?
« Reply #4 on: September 26, 2010, 09:49:43 pm »
Did you follow this instructions:
http://www.mede8erforum.com/index.php/topic,596.msg3343.html#msg3343
Or this translation for Dutch guys:
http://www.mede8erforum.com/index.php/topic,596.msg11818.html#msg11818
You probably forget one of the steps.
Frknzmn
« Reply #5 on: September 27, 2010, 10:06:23 pm »
found a miss translation
Met wachtwoord beveiligd delen inschakelen
 Turn off password protected sharing
tried both of them but still not working....  Huh
mickman
« Reply #6 on: September 27, 2010, 10:30:24 pm »
Did you share some folders? Of course the Mede8er doesn't support Windows HomeGroup. It only support shares via SMB. Search for the folders on your PC you want to share. Right click folder, click properties and then Share.
Also make sure the username and password are correct. Maybe the saved shortcut on the mede8er still contains the wrong password?
Frknzmn
« Reply #7 on: September 27, 2010, 11:00:48 pm »
some folders are shared, tried different accounts also guest account..
filled in the username,password everytime ive changed something..   Cry
Frknzmn
« Reply #8 on: September 27, 2010, 11:02:56 pm »
to login into my Notebook i did not even touch it just filled in username and password and it was a succes..
« Reply #9 on: September 27, 2010, 11:41:00 pm »
Is the computer that is not working added to WORKGROUP and not to a domain or other workgroup name?
We must overlook some setting....
Frknzmn
« Reply #10 on: September 28, 2010, 10:23:25 am »
yes its added to WORKGROUP
Nefkensj
« Reply #11 on: September 28, 2010, 12:09:36 pm »
I have a similar problem that I reported yesterday Although I followed and double checked all directions I can't connect to my PC via Network. Mickman states that MED doesn't support Homegroups. But why then configure it? pls eexplain waht to do with "SMB". (eg. right clicking to share doesn't work with publc folders)
Jos
Med 500X 1TB fw V3.0.4
Belkin F5D8235-4 v1000 fw V1.01.19
W7 64 bits, Intel Core  I3 CPU, 530@ 2,93 GHz 4 GB RAM
Wired cat 5E
Frknzmn
« Reply #12 on: October 02, 2010, 01:49:45 pm »
tried everything over and over again but not working  Huh
shared with everyone
« Last Edit: October 02, 2010, 02:08:08 pm by Frknzmn » Logged
« Reply #13 on: October 02, 2010, 02:00:30 pm »
You might want to try the beta version of V4. that is just released.
Frknzmn
« Reply #14 on: October 02, 2010, 02:09:16 pm »
going to try it now  Roll Eyes
Pages: [1] 2 3   Go Up
