Author Topic: Formatting a 1.5TB Seagate HDD  (Read 604 times)
Sean
« on: November 19, 2009, 03:14:07 pm »
Hi There
I added a brand new 1.5TB drive as the internal drive and formatted it using the built in format utility. Howeve when viewing the system properties is states that I only have 1TB free drive space.  This does not seem to be correct.
Should I rather format it in my PC and then add the put the drive back?
Regards,
Sean Hesom
Ormbett
Senior Member
« Reply #1 on: November 19, 2009, 03:29:34 pm »
Have you upgraded to latest firmware? There is a known bug in older firmware.
Change Log V1.2.2a 18Nov09
1) Fixed Internet Radio Shoutcast IP change
2) Added "search function" Internet Radio
3) Fixed DVD subtitle problem
4) Fixed some spelling mistakes
5) Fixed Hard Drive size reading error on setup Info screen
6) Fixed video info information (video and audio were swapped)
7) Fixed File Copy Network Login screen
Kind regards
Ormbett
•250ml water (cold or soda water)
•200g flour (325 ml)
•400 ml heavy/whipping cream
•butter
Serve with cloudberries and whipped cream!
Insomniac
Moder8or
« Reply #2 on: November 19, 2009, 03:38:20 pm »
Not to worry - that was only a reporting error - you have not lost any drive space.
As Ormbett as indicated, this has been resolved with the latest firmware release.
Update and your HDD will show full capacity.
