Author Topic: how to fix your mkv  (Read 50337 times)
Offline carlalva01
  • Guest
Re: how to fix your mkv
« Reply #15 on: October 23, 2010, 03:06:12 AM »
Spam content removed.
« Last Edit: October 30, 2010, 11:45:20 AM by Insomniac »
Offline Nosoul
    • Wallpapers Synopsis
« Reply #16 on: October 23, 2010, 07:34:14 AM »
Fuc***g spam for useless paying product...
In fact, just use mkvmerge as usual (totally free), and in the third tab for the video file, chose to disable the header compression.
The file will be readable without any problem.
http://www.bunkus.org/videotools/mkvtoolnix/
Offline benalva02
  • Guest
« Reply #17 on: November 01, 2010, 08:23:28 AM »
« Last Edit: November 06, 2010, 07:27:42 PM by Maasbommel »
Offline Nosoul
« Reply #18 on: November 01, 2010, 02:03:17 PM »
Same spammer with other nickname...
http://www.mede8erforum.com/index.php?action=profile;u=10425;sa=showPosts
Must be a lovely swindle if you have to spam like this to spread this paying product....
Offline mtest
« Reply #19 on: March 06, 2011, 03:45:19 PM »
I had the same problem on my mede8er with some mkv files: a blank (black) screen, but i could hear the audio. Some mkv files didnt work at all ("invalid file").
I tried the solution from the opening post, but the .CMD file didnt work. The cmd file says that it requires mkvtoolnix 4.1.1, but the downloadlink from the post is mkvtoolnix 4.2.0, so maybe thats why. So i now i fix my files manually in mkvtoolnix 4.2.0.
Here is a screenshot with instructions:
http://i52.tinypic.com/rmtsn7.jpg
Its dutch but the layout for other languages is the same so it will be useful for non-dutch too.
Offline Nosoul
« Reply #20 on: March 06, 2011, 05:32:32 PM »
This bug is fixed since v4 firmware.
Just upgrade.
Offline tachita_
« Reply #21 on: March 07, 2011, 01:29:05 AM »
that cmd don't require 4.1.1, in principles can be done to work with any version.
it is just a batch script.
@Nosoul is right, use v4 if is fine for you
Offline mtest
« Reply #22 on: March 18, 2011, 09:51:29 PM »
For me this problem actually started after i updated to firmware 4.
Offline tachita_
« Reply #23 on: March 19, 2011, 12:32:46 AM »
Try latest v4.0.4 or beta5.
is very possible to have another issue quite different then header compression
Offline johnnyboy62969
« Reply #24 on: July 02, 2014, 07:52:52 PM »
i dont know what the problem is exactly......
but i had a problem with an mkv file which just wont be able play,rename or delete.....
the only thing that shows when i right click is send to,open with etc.
so i was searching the internet and FOUND THE SOLUTION FOR MY PROBLEM.
i just renamed the folder of the mkv file and the mkv file started acted normally.
now i am able to play it and do watever stuff i want
JUST RENAME THE FOLDER OF THE MKV FILE
i did not discover this solution but i found it on other forums where the user has the same problem with a jpeg file.he just renamed the folder and it worked for him. i done the same and it worked with me too...........
Offline DewaldMeyer
« Reply #25 on: November 12, 2017, 12:31:48 PM »
it appear this topic has gone quiet for a long time but i have the same issue with my mede8ers and mkv files. all of the previous links are not working anymore. can anyone give me advice on fixing the issue?
Offline Pasqulino
« Reply #26 on: February 21, 2019, 05:00:22 AM »
This is a very good thread and can be used in real life.
