Author Topic: uhh, nothing happends..  (Read 570 times)
abisha
« on: September 02, 2010, 05:24:42 pm »
hi all
i aquire today a Mede8er 500, inc HD
but when i plug the USB cable into my computer nothing happends.
i use Windows 7 Ultimate.
and when i switch to the Media box, it shows only a 8.
it dont respond to any commands, including turn off.
i kind of lost, help
problem solved, the HD needed format, but it was lock down, with the USB in the system.
« Last Edit: September 02, 2010, 07:15:15 pm by abisha » Logged
Korras
« Reply #1 on: September 14, 2010, 08:15:26 pm »
hi all
I have the same problem. how did you manage to format the disk? I can access it in windows now, finally, but still it will only display a large 8 on screen, and after a while, it just stops sending anything to the screen at all. changing the input channel I tried: did not help. also, I tried using a regular cable, instead of the HDMI cable, which gives no signal whatsoever, even when trying to change the output signal.
does anyone have any idea what could be causing this? Sad
edit: I think it's safe to rule out the harddisk. it also will not boot without a harddisk.
« Last Edit: September 14, 2010, 08:35:51 pm by Korras » Logged
« Reply #2 on: September 14, 2010, 08:37:30 pm »
When you connect your mede8er to your PC by usb cable, it will run in USB disk mode, responding like a disk.
When you want to use your mede8er to play on your PC, you have to remove the usb cable from your pc and it will boot into normal mode again.
Korras
« Reply #3 on: September 14, 2010, 08:38:50 pm »
yep, I noticed it will reboot if I plug in or plug out a USB cable. however, either way, it will not display anything more then the big 8..
edit: problem found, somewhat. on a different TV, it does show the menu. now, I'll just need to figure out why it won't on the regular TV. I find it odd, though, that it would work on an older tv, instead of on a newer TV, which never had any problems with a PS3, for example, running on full HD..
any idea where to look for the cause?
« Last Edit: September 14, 2010, 08:53:58 pm by Korras » Logged
« Reply #4 on: September 14, 2010, 08:58:57 pm »
You probably have setup wrong video mode.
You can toggle video mode by pressing the TV Sys button, wait some 10 secs, if still no screen repeat this until you get output on the screen.
Suggestion: first read my mede8er beginners guide, link is in my footer.
Korras
« Reply #5 on: September 14, 2010, 09:02:51 pm »
well, I did that, several times, and nothing happened. I changed it on the other TV to 480P, and the aspect ratio to 16:9, and put it back on the regular tv. finally, it showed up. I changed it to the highest resolution on the regular TV (1080P 60hz), and now have a perfect image on the TV.
either way, thanks for the help. Smiley
« Reply #6 on: September 14, 2010, 09:12:07 pm »
Ok, that's another way. But the result counts.
Have fun.
Cheers,
